Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th January 2006, 06:50 PM   #1
Davet is offline Davet  United States
Unhappy Help - with JRSUN Binding Posts
I want to retrofit a set of the JRSun speaker binding post to a set of speakers. Initially I wanted to solder them, but I am afraid that the amount of heat required to heat the post will melt the plastic parts. Thus far using a soldering station, I have not been able to generate anything but molten solder balls.
I then went to try and find nuts that could be used to such that I could screw/sinch the speaker interior wire connection of the binding post, but I could not find nuts that would fit.
How are others making their connections to the JRSUN speaker pinding post?
Davet
Old 12th January 2006, 05:36 PM   #2
Default JRSUN Binding Post Connection
I guess I jumped the gun. The JRSUN speaker binding posts can be soldered using a soldering station with the temperrature set to 750 F.
There was no problem with melting or scorching of the plastic parts.
Davet
binding posts h_a Parts 21 12th January 2009 11:10 PM
kef 107 binding posts dayking79 Multi-Way 1 1st September 2008 11:47 AM
Binding posts cp642 Parts 6 16th November 2001 02:10 PM
Page generated in 0.07197 seconds (74.03% PHP - 25.97% MySQL) with 10 queries
