| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi
I have a Hirakawa AWM E35664 signal cable in my sony cdp 20es does anybody know if it is worth replacing with something better? I looked on manufacturers home page but it is japaneese (is it teflon coated ofc?? THX RAZAW |
#2 |
diyAudio Senior Member
Aren't these the people that used only "natural" insulators? It was reported to be a fine interconnect made of OFC. I wouldn't know what to suggest to you unless you could point to some consistent sonic flaws. Regards,
Frank |
#3 |
diyAudio Moderator Emeritus
Razaw,
If I've got the right URl: http://www.hewtech.co.jp/pdf/cable_do_3839.pdf It says the inner insulation is "poriechiren", which I guess is probably polyethelene. |
#4 |
John,
I can't make much out of the pdf file but it looks suspiciously similar to a bog standard RG58 cable:solid central copper core,polyethylene insulator,copper shield and pvc sheet. Impedance,I'm guessing,75Ohm. Cheers,
Frank |
#5 |
Frank,
It says in English that it's available in both 50 and 75 ohm versions. Probably isn't anything special. I'll probably get a hiding for this; but what difference will 50mm of cable make? |
#6 |
John,
I missed that part. 50mm inside the player,you mean? If it's in the digital section it should not be 50 Ohm,and I wouldn't loose sleep over it if its terminated correctly. If it's in the analogue section and the user has ultrasonic hearing,err...he won't be listening to CD then,would he? Cheers,
Frank |
#7 |
The Hirakawa cable has written on it TC-C I wonder if it means teflon coated. I wonder if replacing it with teflon coated silver military cable will make sens.
#8 |
Razaw,
It doesn't say anything about teflon on the data sheet, just polyethelene. Personally I am a cable sceptic. I just answered this one because I know a little Japanese. Cheers, |
