Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Fake *******ING "MOTOROLA" Transistors
Old 4th February 2006, 03:42 PM   #101
anatech is offline anatech  Canada
anatech's Avatar
That's true enough. I don't know how you can fault the package for that. This would seem to be an intentional way of destroying the part if you ask me.
I have bent a few leads and carefully straightened them back up with no ill effects.
-Chris
Old 4th February 2006, 04:50 PM   #102
K-amps is offline K-amps  United States
K-amps's Avatar
Same here... had no issues, but I can see them rotating if not straightened correctly.
Old 4th February 2006, 11:35 PM   #103
vectorplane is offline vectorplane  United States
vectorplane's Avatar
I'm not faulting the package.
Just comparing that it's harder to do this to a TO220.
If you look up the properties of glass you'll see it's not as resistent to stress as epoxy.
My only point was that some care is required in handling the TO3.
You dont have to take that advice; you are free to abuse it as you wish.
Old 5th February 2006, 12:48 AM   #104
clem_o is offline clem_o  Philippines
Originally posted by vectorplane
Question for anyone who has cracked open flat packs (TO220, 247, 264):
Is the top face of the die in direct contact with the epoxy molding material, or is there a small space of air above it?
Hi vectorplane - I'm late into the discussion - again. Why the question anyway? You looking at extra capacitance due to the epoxy?
One of the problems with epoxy is actually bending of the gold wires, causing shorts. This is caused by the plastic not quite being liquid enough as it is injected and molded. So, the stuff definitely gets into contact with the silicon and would be out-of-norm to have voids...
Cheers!
Clem
Old 5th February 2006, 12:51 AM   #105
anatech's Avatar
Hi Vectorplane,
I don't think epoxy would survive that test either in the same mechanical configuration. Epoxy packages have their own issues, so I think you simply have to be aware of the issues with whatever package you are using.
This is a bit O.T. anyway.
-Chris
Old 5th February 2006, 02:15 PM   #106
Clem:
Do you still need to pursue a uC solution?
Or are you ok with using a capacitince meter.
The question about epoxy voids was to determine if an additional heatsink placed on TOP of the flatpack could in some cases be implemented for enhanced heat removal from the die.
(ie. sandwich the flatpack between 2 heatsinks)
Andy
Old 5th February 2006, 03:09 PM   #107
anatech's Avatar
Hi Andy,
There would be problems with the leads that attach to the die. They are attached from the top "flying" as it were. When you crack a transistor apart, these normally leave with the top encapsulation.
-Chris
Old 5th February 2006, 11:15 PM   #108
Default OT: encapsulation voids
Originally posted by anatech
Hi Andy,
-Chris
Chris, I'm not sure which question you're addrssing.
If there are no voids in the epoxy, it means that both sides of the flatpack can be used to conduct heat away.
For any given heat sink arrangement, anytime you want to add an additional 5 square inches of heat sink, it's better to add it close to the device, than at the extremity of an existing heat sink.
But if there is a void inside the epoxy, than removing heat through the top face becomes less attractive.
The above might be relevant only if you need to minimize thermal resistance(case-to-ambient) in a space-constrained application.
Again, sorry for the OT.
Andy
Old 5th February 2006, 11:20 PM   #109
anatech's Avatar
Hi Andy,
Sorry for being ambiguous. I was answering
Although not very clearly.
You would be further ahead to contact the heatsink around the device and provide more surface area on the top side too. That is sometimes seen.
-Chris
Old 5th February 2006, 11:41 PM   #110
Hi Andy - I'm certainly fine with using a capacitance meter - but I do have to check if my unit is up to it (many things seem to have gotten in the way this weekend)...
re: additional heatsink on top of a flatpack - I don't remember the specs from sumitomo plastics, but had the impression that the thermal resistance wasn't that good. The only reason the top gets hot "faster" than the rear is the low thermal mass, so it will probably help only a little...
Cheers!
Clem
Fake *******ING "MOTOROLA" TransistorsHide this!Advertise here!
4" Seas long throw woofs, Motorola piezo compression drives, TangBand 2" widebands mr_ro_co Swap Meet 4 15th April 2008 01:16 AM
"japanese" Transistors To "european" MYLEY Parts 4 23rd February 2006 09:02 PM
New "Fake Components Forum" ashok Everything Else 3 9th May 2004 02:30 AM
