Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
where to buy a nice toroid transformers
Old 8th January 2006, 07:54 AM   #1
paulyang is offline paulyang  United States
Default where to buy a nice toroid transformers
i need 9-0-9 and 18-0-18secondaries .....0.0a
about 3A or 2A for each.....0.0a
Does somebobdy know where to get this stuff???
thank you!!!
Old 8th January 2006, 10:47 AM   #2
forr is offline forr  France
forr's Avatar
Hi Paulyang
Are you sure the toroid technology is nice for audio ?
~~~~ Forr
Old 8th January 2006, 11:29 AM   #3
Upupa Epops is offline Upupa Epops  Czech Republic
And what is " nice for audio ", Forr ? Some excaved transformer from the year 26' ?
Old 8th January 2006, 01:54 PM   #4
forr's Avatar
Hi UPUPA EPOPS
There has been a lot of discussions on this forum about pros and cons of toroidal transformers. From them, I retained that they are not the best suited for immunity against mains parasitics. So I define "nice for audio" by negativity as avoiding defects, otherwise said : "blameless".
~~~~~~ Forr
Old 8th January 2006, 10:51 PM   #5
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Plitron's standard toroid transformers are very nice but pricey. You'll also have to wait 4-6 weeks for them to make and deliver one.
Brian
Old 10th January 2006, 05:02 AM   #6
EWorkshop1708 is offline EWorkshop1708  United States
Originally posted by forr
Hi UPUPA EPOPS
~~~~~~ Forr
Just add an inductor and some caps for mains filtering
Old 10th January 2006, 05:25 AM   #7
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Digikey has a PC mount 9-0-9 transformer that would suit your needs at a reasonable price - part number TE70081-ND
parts express has an 18V Avel that is a bit large, at 160VA, but under $40
Avel Lindberg will also sell direct, and has a broader range than PE carries, including a couple of options for both of your requirements. Although not quite the reputation of Plitron, their Chinese made Y23 line is good quality. I have used a few higher power ones. No mechanical noise and good regulation.
Toroid of Maryland www.toroid.com also sells direct and makes good quality transformers. I used their products, too.
Victoria Magnetics has an excellent reputation, and will do customs at near standard prices. Do you need both voltages for the same project? they'll probably be able to wind you a dual secondary transformer for less than two individuals. The catch is the wait - about the same as mentioned for Plitron.
Old 10th January 2006, 06:06 AM   #8
Dear all......
i got some information from you guys.....
thank you for that ......
the reason i need to use toroid transformers because i have not much place to put nice Ei or some other nice transformers...so i need to save some spaces....otherwise, the reason why i don't want to buy toroid transformers at digi key because they do not offer 9-0-9 and 18-0-18 in ONE!! the second reson is I preffer transformers made in USA or in Eourp .....0.0"
By the way......this transformers is for my Studer 727 CDP.....0.0a
where to buy a nice toroid transformersHide this!Advertise here!
Toroid transformers metalmaster Tubes / Valves 1 21st November 2003 08:54 PM
toroid transformers karma Swap Meet 17 27th February 2003 10:12 PM
Toroid transformers Michael Rothacher Swap Meet 5 29th November 2002 02:59 PM
Toroid transformers peranders Swap Meet 5 5th October 2002 02:15 PM
Copyright ©1999-2017 diyAudio
