Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th January 2006, 05:37 AM   #1
philb is offline philb  Canada
philb's Avatar
Question Quality capacitors without breaking the bank
I am building Rod Elliot's constant Q expandable graphic equaliser. http://www.sound.westhost.com/project75.htm .
I have been reading and re-reading his article for a few weeks putting together everything i can find. I have come to choosing components, and have run into a snag. I would like to use foil polyprop caps, but since the circuit requires so many caps i will be broke. Also 1% metal film capacitors are not cheap.
I was looking at digikey BC components metalized POLYESTER film caps, and yageo 1% metal film resistors.
Are these good choices, or are is there a better bang for my buck? Thanks guys.
Old 6th January 2006, 05:46 AM   #2
sagarverma's Avatar
both r good.
i made his 12db xover with philips m/f caps.its working great.
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 7th January 2006, 04:06 AM   #3
Can you give me a page number in their online catalog for these?
I did a search and see only polypropylene listed for BC components. Even so... I couldn't find any metalized versions.
I used Polypropylene Film from EPCOS @ 5% tolerance in my last EQ project. They work good.
Writing is good exercize for the texticles!
Old 7th January 2006, 09:06 AM   #4
jpl is offline jpl  Australia
jpl's Avatar
Try E-bay very cheap .
Old 8th January 2006, 09:06 PM   #5
philb's Avatar
head_spaz
the BC components caps were metalized POLYESTER film caps, not polyprops. Thanks for the heads up on epcos polyprop caps, but i think for a few bucks extra i will go with the tighter toleracne of the BC componenets metallized POLYPROP filter caps, unless there is a reason i should not.
I will aslo check e-bay but i don't think i will find all the value.
Thanks fot the help, i'll post pics when i start building.
low Qes 3-5" midrange driver without breaking the bank Puggie Multi-Way 1 16th November 2006 02:06 PM
Quality Capacitors in UK iamwhoiam Parts 2 27th January 2005 07:18 AM
high quality switches, bank connectors Drew.J.K Parts 0 4th August 2004 03:34 PM
UpgradeWithout breaking the bank Eagleman6722 Solid State 0 4th November 2003 05:25 PM
Capacitors quality for NON-OS dac with TDA1541 hifiwolf Digital Source 44 3rd January 2003 09:46 PM
Page generated in 0.08854 seconds (75.43% PHP - 24.57% MySQL) with 10 queries
