Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Calibrating new tip on Hakko 929-2 / 903
Old 4th January 2006, 02:53 AM   #1
ultrachrome is offline ultrachrome  United States
Default Calibrating new tip on Hakko 929-2 / 903
I just bought the A1243 tip for my Hakko 903 iron. I'm a little confused about the calibration process.
The 929-2 instruction manual says to adjust the calibration pot to room temp, however the soldering tip packaging says to use the offset value.
The A1266 tip that came with my iron is marked with a -38F offset value. In calibration mode, the station is set to 38.
The new A1243 tip is marked with a -31F offset.
What should the station be set to?
Old 4th January 2006, 03:28 AM   #2
poobah is offline poobah  United States
poobah's Avatar
31
Calibrating new tip on Hakko 929-2 / 903Hide this!Advertise here!
Calibrating an emission tester kenpeter Tubes / Valves 5 30th June 2008 05:56 PM
Calibrating electronic Ph meter Netlist Equipment & Tools 7 14th April 2007 07:46 AM
self-calibrating OPAMP jackinnj Swap Meet 0 27th February 2004 06:03 PM
Calibrating a mic Raka Analogue Source 1 29th January 2003 07:28 PM
