Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd January 2006, 09:39 PM   #1
Default +/-15v Power supply
I need a small balanced power supply. The consumption of th original was 110 Volts 12 watts. Not sure of my actual demand. I'd like like someting simple if possible because I am an electronics novice. I was even consider using wall warts. I have plenty of them but don't know the circuitry. I have a couple of rack mount power supllies but they push 17 volts. Is that too high?
Old 3rd January 2006, 10:23 PM   #2
Keld is offline Keld  Sweden
Keld's Avatar
If you tell us what you're building it would be lot easier to help you out!
"What is done by what is called myself is, I feel, done by something greater than myself in me."
James Clerk Maxwell. 1879
Old 4th January 2006, 02:23 AM   #3
Default Power supply
I am working on a Yamaha CS-15 Analog synthesizer(1970s). It has a number of issues including the power supply. I can't begin to repair it until I have a known good power source. The ICs in the original power supply are hard to get and cost will add up to more than I want to spend
Old 4th January 2006, 07:10 AM   #4
Keld's Avatar
have look here:
http://sound.westhost.com/project05.htm
http://sound.westhost.com/project05a.htm
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.07451 seconds (72.54% PHP - 27.46% MySQL) with 10 queries
