| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I was wondering where you people obtain your moving coil meters for vu, power, etc 'measerument' purposes. I just want to include two (left&right) power meters and one temp meter on the front of my amplifier, but I can' t find any moving coil meters. Well, I did find some, but they are either ugly and sealed or I've to order 1k pieces of them. Then they are custom machined, hence beautifull, but I need only three .I think I only need the moving coil+needle itself, then I can make my own backplane for it. (Seems Passlabs does the same thing and that looks very neat). Thanks in advance, Remco Poelstra |
#2 |
Two people can keep a secret if one of them is dead. |
#3 |
Thanks for your reply. Seems to be what I was looking for. Hope the scales can be replaced, but they at least have a distributor around the corner, so I should be able to get them. Remco Poelstra |
#4 |
Hi Remco,
Sifam is good quality and their meters last for life but these are expensive (around 60 eu). It is not in your area but in The Hague there is a surplus store called Radio Twenthe. It has many nice old stock moving coil panel meters for cheap incl VU-meters and several cheap Japanese VU-meters as found in old tape recorders. No electronic surplus store in Eindhoven? Cheers
#5 |
Thanks for the tip. I can travel free by train, so The Hague shoudn't be a problem . I don't know any surplus stores in Eindhoven, only Display/Coditronix. But, well, you now them, expensive and quite small assortment.If I can check the meters in the store, then I can see whether I might be able te replace the backplane in order to convert the thing to a power meter ![]() Remco Poelstra |
| Moving Coil preamp design | paul joyce | Solid State | 162 | 26th October 2010 11:36 PM |
| Trashed moving coil Multi-meter???? | bigpanda | Everything Else | 2 | 6th July 2008 04:48 PM |
| Meridian 101 moving coil module | RCruz | Analogue Source | 1 | 24th April 2007 11:34 PM |
| moving coil loading | lt cdr data | Analogue Source | 28 | 27th June 2005 10:50 PM |
| SL10 Moving Coil Stage | johnsciolino | Pass Labs | 1 | 25th October 2004 06:05 PM |
| Page generated in 0.09001 seconds (66.63% PHP - 33.37% MySQL) with 10 queries |
