Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th December 2005, 03:07 AM   #1
hotscot is offline hotscot  Scotland
Default Finding Capacitors
Without specialist knowledge I'm trying to fix an old Marantz PM 66 KI amplifier.
It's missing two capacitors value 12000 uF, 56V.
1. Can anyone advise me on where to purchase these?
2. And does it matter what type they are or is it the values that are the most important aspect.
Alan
Old 30th December 2005, 07:56 AM   #2
establish the footprint and pin pitch the caps MUST fit. Check the temperature rating (common ones are 70, 80 and 105degC.)
12mF is a slightly unusual value but is available.
56V is also slightly unusual.
Combined, these two values, probably mean that only a few maunufacturers make an identical product.
Marantz probably do this to dissuade DIYers and non franchised repairers from repairing their products.
Try to find a cap with near 12mF and a voltage rating = or slightly above 56V, that also meet the first physical requirements.
63Vdc is perfectly OK. Any higher voltage eg. 75V or 80V may make the package too large to fit the space available.
regards Andrew T.
Old 30th December 2005, 08:17 AM   #3
diyAudio Moderator Emeritus
jean-paul's Avatar
Please check 15.000 uF 63 V of various manufacturers. When they fit physically ( check diameter, height and distance between the lead wires ) they will be an excellent replacement.
Elna LP5 series are OK if you can find them.
It's only audio
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Newbie: Help finding 560nF capacitors for electronic crossover? americantabloid Parts 6 26th July 2007 10:38 AM
Need help finding capacitors SideA Parts 2 23rd April 2003 09:33 PM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.08579 seconds (68.24% PHP - 31.76% MySQL) with 10 queries
