Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Transfomer Trouble, don't dare plugging it in
Old 24th October 2002, 07:46 PM   #1
Christian is offline Christian
Send a message via ICQ to Christian
Default Transfomer Trouble, don't dare plugging it in
I juste took an xformer (not toroid) out of an older amplifier, and I have used it in test setups. But there was a switch there for setting the mode between 110-220 Volts input voltage.
Now, I have taken it away and cut the wires abit, but I measured in advance that I didn't change anything.
So, now I'm a little frightened plugging it in again, so I guess my question is; What's the worst that could happen?? if it's now set for 110V anyway.
any experients with these kinds of multiple winding transformers will probably help, I'd be glad to post a pic.
/Chris
Old 24th October 2002, 08:34 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
See this thread, maybe you can use the info.
http://www.diyaudio.com/forums/showt...&threadid=7065
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 61 paid.
Old 25th October 2002, 12:53 AM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default XFORMER
Christian,
Worst case scenario : transformer smokes and shorts itself.
Just for future reference:
Before changing anything make a little drawing with what goes where etc.
Rgds,
Frank
Old 25th October 2002, 01:26 AM   #4
NickC is offline NickC
install fuses before turn on the amp
i install my trans wrong before.
230 v for 120v connection
the fuse blew then i new what i did wrong
fuse 5a slow blow. Normally trans can withstand over current for some number of time
Old 26th October 2002, 12:42 PM   #5
MRehorst is offline MRehorst
MRehorst's Avatar
There are a bunch of threads here about identifying transformer leads- do a search.
When I am going to work on a piece of equipment I use my digital camera to take many photos from multiple angles before I start taking things apart. That way when it is time to reassemble I have a clear, colorful reference as to what was what back when I started. This is especially useful if you get interrupted in the middle of what you're doing and can't get back to it for days, weeks, or even months.
It also helps to make sketches showing where different sized screws go...
MR
Old 26th October 2002, 02:57 PM   #6
I've now Fired It Up! It still works. Didn't use fuses, couldn't find any at the time and my fingers were twitching, so....
But I kept a good distance and watched the output voltage.
I guess my initial fears where that it would blow up. But I'm still here, and it works nicely.
Next up will be the mechanical isolation, it makes quite some noise when I put it on a table. So i glued several layers of rubber feet under it, and know it's almost completely silent.
thanks for the help alll of you!
and by the way - Fred Dieckmann - I'm also a Swede :-)
/Chris
Transfomer Trouble, don't dare plugging it inHide this!Advertise here!
Plugging subs directly into 120V Inductor128 Class D 4 5th October 2008 05:00 AM
Plugging headphones into Echo Mia slowpogo Everything Else 2 28th February 2007 07:29 AM
plugging guitar amp to phono reciever 9am53 Instruments and Amps 4 2nd June 2005 04:15 AM
Think this is worth $60? (transfomer) Hybrid fourdoor Swap Meet 5 22nd June 2004 10:56 AM
Switching off speakers when plugging in headphones? Christian Everything Else 20 28th August 2002 09:35 PM
