Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
making battery charger?
Old 29th December 2005, 08:25 AM   #1
WordUpOnLCDs is offline WordUpOnLCDs  United States
WordUpOnLCDs's Avatar
Default making battery charger?
How would I go about charging Koyo My 12v BAttery with my 18VDC @ 5.5VA hobby transformer? Is it possible without alot of work I havent really done this kind of stuff before. I also have some different power supplys Ive gathered over the eyars such as 12VDC @ 500ma, 5.0DC solid line over dotted line 2.0A?, 11.2VDC @20ma, and a bunch more laying around, if its any help. Thnx
Old 30th December 2005, 08:37 AM   #2
you need to achieve 4 targets with your charger.
1. set a current limit to avoid overheating and gassing, your sealed battery requires a different charging strategy from old technology lead acid.
2. set a voltage limit to avoid overcharging and gassing. I think sealed require about 13.8volts.
3. establish the VA required to meet the above for quick charge (not less than 10hours) any quicker risks damaging the battery.
4. find info on temperature compensation for the voltage limit related to battery temperature.
A nice option would be automatic change over to trickle charge when full charge and/or highest temperature is achieved.
Another nice option is reverse polarity protection.
regards Andrew T.
Old 30th December 2005, 10:02 AM   #3
is it advisable to use an adapter I have that is 12vdc @ 500ma to charge it? I mean is it safe?
Old 30th December 2005, 06:30 PM   #4
12Vdc will not charge a 12V battery. You need more than 12V to overcome the battery voltage plus the resistive losses in the charging circuit.
regards Andrew T.
Old 30th December 2005, 09:40 PM   #5
Stocker is offline Stocker  United States
batteryuniversity.com
Jesus loves you.
Old 31st December 2005, 08:30 AM   #6
would an automotive float charger work to recharge my battery or does that only maintain it? like these i found on ebay http://cgi.ebay.com/TWO-12V-AUTOMATI...QQcmdZViewItem
making battery charger?Hide this!Advertise here!
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 03:18 PM
R/C battery and charger jaudio Power Supplies 3 18th February 2009 08:27 PM
12V Battery Charger for Car Wynand Everything Else 10 16th November 2006 12:25 AM
SLA Battery Charger doomsweek Digital Source 2 21st November 2004 11:04 PM
Copyright ©1999-2017 diyAudio
