| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello.
i got some transformers made in india on my way back to Australia. Im a bit worried about them though. They dont seem to be working. What looks like the primary windings (really thick and stiff) i plugged into the mains (240V in aus) it tripped the circut breaker. So i measured the resistance of these wires and they are about 0.06 ohms, ie nothing. How could this transformer ever hope to work? It obviously drew a lot of current and tripped the breaker. The secondries(smaller red wires) have about 12 ohms resistance. I asked for 240V to 22V. It has written on the side of it 0-22V not sure what this means? I hope i havent been ripped off..... |
#2 |
You or the supplier have got the primaries and secondaries mixed up.
The primary is the high resistance winding! |
#3 |
in the few milliseconds it took for the trip to cut off, the primary was trying to produce 2500V across the windings. Take care!!!! Do you have single primary and single secondary on each transformer? Then easy to connect. If you have dual primary and/or dual secondary then be very careful how you connect the windings. If out of phase then you could burn out the transformer or if you are lucky the CB will trip again.
regards Andrew T. |
#4 |
Crossposting see this:
voltage ok? |
#5 |
When working on projects like this use a variac to bring up power. If a variac is not available, use a light bulb in series with the load (xfmr in this case) to prevent damage. There's no excuse for tripping breakers. Work safe!
| Amp. troubles PLZ HELP!!!! | ReverB | Car Audio | 5 | 1st November 2009 01:11 AM |
| SW troubles... PIA | nunayafb | Multi-Way | 7 | 30th March 2006 12:04 PM |
| dvd 963sa troubles... | Htguy | Digital Source | 0 | 27th July 2005 10:01 PM |
| ZV5 Startup Troubles | keenlyside | Pass Labs | 0 | 13th June 2005 06:35 AM |
| amp troubles | squid6 | Tubes / Valves | 5 | 8th July 2004 06:50 AM |
| Page generated in 0.08982 seconds (74.79% PHP - 25.21% MySQL) with 10 queries |
