| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
hey
i went 2 RS-compnents 2day for wallin jig2. though the shop doesnt stock everything. im missing: 1* 8ohm non inductive 20W 5% resistor 8* 16.2ohm 1/2W 1% resistor i found the 8 ohm on parts express, but a 16ohm 1/2W 5% was the cloest i could get for the 16.2 plus they have their $50min fee which i wont reach... so any clues where i can get these last couple from. much appreshiated jens. |
#2 |
with the 8 16.2ohm 1/2W 1% resistors there are two required results obtained when they are wired in series/parallel:
16.2ohm 2W resistor (wired series and parallel)and 4.05ohm 2w resistor (wired all in parallel) i was wondering if it would b fine 2 make a slight adjustment on the values by using 2 15ohm and 2 18 ohm in each arrangement giving: 16.5ohm and 4.09ohm. would this slight change be a significant difference. im not electrically minded.... much aprreshiated |
#3 |
Electrons are yellow and more is better!
What are you going to use these resistors for? What are the precision demands?
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
im using the resistors for Wallins jig II
R5, R4 are the made up resistors R1 is the 8ohm http://mysite.verizon.net/tammie_eri...jig2/jig2.html i think ill have 2 ship from over seas. Eric wallin on his page recommends DigiKey BC16.2ZCT-ND (16.2 ohms) or radio shack a 16 ohm... as long as the final value ends close to 16ohm and is measured properly for correct callabration. but this resistor 16.2 ohm is .6w i have no idea what that does, i assume it would be ok. i think it just means it can adsorb more wattage? |
#5 |
#6 |
Warp Engineer
On Holiday
I don't usually recommend them (there are much cheaper places around for 99% of what most of us need) but Farnell can almost certainly get you what you want and deliver it to your door in a couple of days or less. Will certainly be quicker and cheaper than ordering from overseas.
http://au.farnell.com/
- Dan |
#7 |
16r2 = two series connected 8r2//1k3 or 18r//160r. Use 500mW or 600mW 1% for each resistor. Over rating the dissipation should make no difference to the circuit.
regards Andrew T. |
| 5 Watt Resistors on Aleph 4 and Holco Resistors | nicharis | Pass Labs | 16 | 8th February 2012 07:50 AM |
| FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers | chris-man | Swap Meet | 1 | 28th May 2009 11:47 AM |
| WTB: a couple of 1.8K Ohm high spec resistors | jives11 | Swap Meet | 0 | 21st September 2007 08:02 AM |
| cap couple or direct couple class A SE amp? | AudioGeek | Solid State | 7 | 7th May 2005 06:16 PM |
| Page generated in 0.09424 seconds (78.97% PHP - 21.03% MySQL) with 10 queries |
