| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#31 | |||
diyAudio Senior Member
Hi there,
In laymans terms,it can drive even the most unreal stuff. Quote:
I wouldn't touch the PSU,it's pretty much beefed up as is. About 100 x that of any other preamp you can find:regulated (valves) B+ for every single tube,left and right channel separately, 500mF storage perchannel and so on,four dedicated transformers,dual moni to extreme.... Why would anyone change that? Quote:
Frank |
#32 |
Thanks frank,Will deffinately start with the caps,sounds like your unit was modded before?Mine looks like its still in its original state
the sound is very remarkable but having heard more expensive caps i think that the rs ones are letting it down I tried jeff waynes "the war of the worlds soundtrack"on remasterd sony cd and this was so incredibble i had to go in the garden and get some fresh air,when the alien lid fell off on the common i "felt"instead of "heard"the weight of the metal being moved.Sometimes i wonder if this is possibly one of the best pre-amps ever built.In todays money it must cost a fortune to construct An unknown legend Thanks for the imfo on the psu,like you say Frank everything is pretty well taken care of,good point
#33 |
Maybe mine is not his run off the mill stuff but I got it directly from Glenn so no previous modding there. Back in the early nineties I changed the coupling caps for MIT polysterene and foil,the pots for selfmade 1M rotaries,cathode resistors for Holco (I regretted that) and all series resistors with Vishay S102 bulk foils(at 20 UKL a pop),I used leadfree silver solder and replaced all wiring with silver wire. I perfected the RIAA correction to get 0.08 dB tolerance,upped the cathode decoupling caps (WIMA polyester standard) with some extra MKPs to gve me 10Hz extra bandwith in the bass (you need a well isolated TT for that) and that is about it. In all honnesty it was about a 10% improvement,just to give you some idea about how good it was standard. We have a thread on volumecontrols: Ladder attenuator: Where to solder resistors The addictive part about this design is IMO dynamics,awesome! CDs sound compressed in comparison. Regards,
Frank |
#34 |
Brilliant imfo Frank,100%usefull.Not to many have shed me any light on this pre-amp since i owned it 5 years ago.
Have printed off all of the mods that you mentioned and was thinking of taking the unit to croft who are now based in IRONBRIDGE.All of the main caps in the output look cheap and nasty so i think any upgrade should take it a step closer to its full potentiol Was thinking of making the cable lenghts shorter within the top box and less bunched up and taking out the tape facility. Have you any idea what the valve comliment is on this pre Frank,reason being the valves in my unit do not have very readible text on them and i am curios to which valves to order The volume control sounds fassinating,will deffinately give this some reading, I have just took some pics of the pre and will try and scan them inn Many Thanks, |
#35 | ||
Phonostage 1 x ECC83 per channel (Telefunken's are his favourites,same goes for me,another make that sounds fine is the E83CC from TESLA) Finally the 12BH7A,I don't think you will hear much difference there,it's a CF) Hope this helps,
Frank |
| Audio note, kimber Kap, Jensen caps f/s | 240z4u | Swap Meet | 1 | 24th June 2007 11:31 PM |
| Replacing multi-section caps with multiple caps? | Sir Trefor | Tubes / Valves | 1 | 29th May 2007 10:17 PM |
| Silver Mica caps VS Polystyrene caps | KevinLee | Parts | 24 | 17th September 2003 03:01 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 01:02 PM |
| FILM Caps to assist Big ELYT Caps | gromanswe | Parts | 0 | 9th July 2002 08:16 AM |
