Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Pioneer Series 20 Ring emitter transistor recommendations needed
Old 22nd December 2005, 06:56 PM   #1
brothelthug is offline brothelthug  United States
Default Pioneer Series 20 Ring emitter transistor recommendations needed
Hello everybody!
I have a dead Pioneer series 20 A27 amplifier in need of output transistors (I suspect that the series 20 m25 amplifier utilizes the same) .
They are 2sa1003 and 2sc2323 ring emitter transistors (to-3 case). I haven't been able to find any info or substitutions for these parts.
Googling around I found the following Ring Emitter transistors...
sanken 2sa1494 and 2sc3858
or
"super linear" 2sa1943 and 2sc5200
or
"the ultimate audio power transistor" 2sa1216 and 2sc2922
Would any of the above be a suitable replacement?
Does anyone out there have any data on the 2sa1003 and 2sc2323 ring emitter transistors? Or any recommendations to overcome this quandry?
Thanks, Ted
Old 22nd December 2005, 07:16 PM   #2
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Are you sure the RETs are dead ?
I have a M25, RETs are MN25 and MP25.
Old 6th January 2006, 09:10 AM   #3
Hi Bernhard,
Thanks for your reply.
I took them out and measured them ... a few are shorted.
Cheers, Ted
Old 6th January 2006, 10:06 AM   #4
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Default Re: Pioneer Series 20 Ring emitter transistor recommendations needed
The data:
Vcb/Vce max=150 volts
Ic max=12 amps
Ft= 20 MHz
Hfe = 50-200. 100 typical.
Pt = 120 watts
Manufacturer= Fujitsu
If it is possible to change to a different case i'd go for the Sanken 1216/2922, you will not find TO3 multi emitter devices.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 6th January 2006, 10:10 AM   #5
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
You don't have to use ring emitter types as replacements. Choose from the ones you listed that have the same case style, they are all good.
Watch out for fakes, be careful where you buy from.
It would also be worth replacing the driver transistors as failed output devices often take out or at least damage the drivers.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 17th May 2006, 02:01 AM   #6
Thanks for your help!
I'll try some non ring emitter transistors.
Cheers, Ted
Pioneer Series 20 Ring emitter transistor recommendations neededHide this!Advertise here!
four transistor emitter follower (diamond buffer) as power output stage? capslock Solid State 114 22nd February 2015 11:51 AM
PowerBase vs LAPT or ring emitter techology roender Solid State 5 22nd December 2007 02:41 PM
Need medium-power transistor recommendations abzug Solid State 4 20th December 2007 02:46 PM
Why are Emitter-resistors needed? Fritzell Solid State 11 5th February 2007 07:04 PM
Transistor and MOSFET recommendations? meretrix Parts 2 24th January 2005 12:45 PM
