Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Big Heat Sinks
Big Heat Sinks
Old 22nd October 2002, 06:22 PM   #11
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
but (original question once again), 1 18" section per channel would be enough cooling? vertically or horizontally?
i assume that 2 18" sections per channel is enough also...
Originally posted by BrianGT
I was thinking of the wrong heatsinks... I was thinking of the other big heatsinks that they used to offer.
Cutting them in half seems like the best plan to me and would provide a better looking chassis.
Brian
Old 22nd October 2002, 06:24 PM   #12
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I don't think that one 18" would be enough.
I would instead, cut the heatsink in 3 even pieces, buying 3 heatsinks total, and using 4 of these pieces per channel, orientating the fins vertically.
That would give you 2 chassis that would be ~8" high and 21" deep.
I would then use one of these chassis per channel. You could then mount 3 devices on each of the heat sinks in the big middle part.
Brian
Old 22nd October 2002, 06:34 PM   #13
BrianGT's Avatar
Similar to this, but with your heatsinks:
Brian
Old 4th November 2002, 07:20 PM   #14
jgwinner is offline jgwinner  United States
Brian:
Do you think a plastic/aluminum blade in a chop saw would work to cut these?
I assume a bandsaw would be best, but I don't have one of those. Table saw and a chop saw I do have, and I've cut aluminum in those (with backing), but these heatsinks have a lot of fins, I'm not sure how well that would work.
== John ==
Old 4th November 2002, 07:25 PM   #15
BrianGT's Avatar
I would think that if you had the right blade and clamped it down tightly, you could get a good cut with the chopway (it is the same as a sliding miter saw, right?)
More pictures of PedroPO's amp in this thread:
http://www.diyaudio.com/forums/showt...&threadid=7278
Brian
Old 4th November 2002, 07:36 PM   #16
Correct, it's a woodworking saw, although it doesn't slide. It's a 12" compound miter saw.
I've seen problems with thin pieces (1/8") of Al (L piece) going through the table saw; sometimes the piece of Al 'flexes' and then it tends to 'shoot'. I started clamping a piece of wood on the top of the Al L, in addition to the wood fence behind it.
Kickback is not fun but that should be less of an issue with the Compound Miter saw.
== John ==
Big Heat SinksHide this!Advertise here!
FS: Heat sinks gengis Swap Meet 8 17th March 2006 01:27 AM
Heat Sinks serengetiplains Parts 3 3rd January 2006 06:41 AM
heat sinks D3 Pass Labs 9 29th December 2003 07:19 AM
Heat sinks - going the other way jackinnj Everything Else 9 27th April 2003 05:01 PM
