Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
2nd/4th order filter response
Old 28th November 2005, 12:56 AM   #1
muhy3 is offline muhy3  Australia
Default 2nd/4th order filter response
I am just wondering if the following bode diagram of a 2nd order filter (Q=0.707) is correct, Fo = 20Hz (blue line) and the green line is two 2nd order filters (multiplied together in MATLAB). Does this mean that the new Q = 0.5? Also does the response modelled by the filter look sharp enough to prevent over-excursion on my XLS12? The tech-sheets specify Q=0.7 and Fo=20Hz, but I just don't think 6dB/oct is enough, or perhaps a higher fall-off would be better.
What do yous think?
There used to be a time, when penguins filled the sky!
2nd/4th order filter responseHide this!Advertise here!
First-Order Lowpass Filter with a Cap Taterworks Multi-Way 6 14th October 2007 02:55 PM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 05:50 PM
1st order low-pass filter, which cap ? Thmartin Parts 4 17th November 2005 09:37 AM
Help in measuring response of 4th order BP box venki Subwoofers 13 14th November 2005 10:45 PM
5th order filter chip Russ White Chip Amps 8 9th June 2005 05:19 PM
Copyright ©1999-2017 diyAudio
