Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Right Channel not working on Stereo reciever
Old 28th November 2005, 03:33 AM   #1
nicku1302 is offline nicku1302  United States
Default Right Channel not working on Stereo reciever
Hey everyone, i have a Technics AV stereo reciever(SA-EX110) class H+ and the right channel just stopped working one day. It is a 300 W receiver with 2 sets of stereo outputs. One set of outputs can only be run at a time A or B. I tried using the second set of outputs(outputs B)but only the left channel works still just as in stereo outputs A. I also tried to alter the balance all the way to the right channel but nothing comes out. I opened it up and saw no visible signs of blow out caps or resistors....Can anyone help me fix this ?? It's crucial that i get this working or my house parties will be no more... thanks
Old 29th November 2005, 03:32 AM   #2
anatech is online now anatech  Canada
anatech's Avatar
Hi nicku1302,
Are you good with a soldering iron?
Technics are famous for many bad solder joints on the jacks at the rear of the board and also the parts that mount to the heatsink. Do yourself a favour and use liquid solder flux (for PCB work!). Add very little solder and redo all of these. Also watch the fan connections.
If you aren't good with a soldering iron, have someone do this that is good. Use a good temp. controlled iron.
-Chris
Right Channel not working on Stereo recieverHide this!Advertise here!
New K-12g only one channel working audioblast Tubes / Valves 9 14th May 2007 02:13 PM
WTB: Stereo Reciever, Plate Amp, CSS FR125S Evazan Swap Meet 9 28th September 2006 05:35 AM
bridging channels on stereo reciever 9am53 Solid State 10 8th December 2005 04:16 PM
stereo hifi project with fm reciever gideon Chip Amps 2 24th October 2005 07:38 PM
My Stereo Encoder Design not working -- PLS HELP..! xitronics Everything Else 11 28th May 2005 04:51 PM
Copyright ©1999-2017 diyAudio
