| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
To work optimal, the way its intended, there should be NO connection between cap pins on printboard
The trick of the 4-pole is that power goes in at one end of cap foil, and out at other end This means that power goes through the cap, instead of just "passing" at the solder pins ESR/resistance is higher Multiple paralel caps is less ideal Aother issue is the foil/pin connection That always presents a problem And with 4 poles theres just even more connections to handle Be aware that there are two different pin versions (Jensen) And caps are poorly marked, so you need to carefully check the specsheets I use a single pair of Jensen 15.000uf 4-poles in my 40watt poweramps, with good result Tho being good caps, I wouldnt use them again |
| FS: UcD40HG HxR, Jensen 4-Pole Caps | PHilgeman | Swap Meet | 3 | 24th January 2009 03:17 PM |
| WTB: Jensen 4 pole caps | max29 | Swap Meet | 0 | 7th November 2007 08:03 AM |
| Anyone have a model for Jensen 4 pole caps? | tonyptony | Parts | 0 | 30th July 2007 02:06 AM |
| FS: 4 pole Jensen CAps and stereovox digital cable | wendell c | Swap Meet | 0 | 10th October 2006 09:51 PM |
| WTB BHC or Jensen 4 pole caps | deandob | Swap Meet | 0 | 11th March 2006 11:10 PM |
| Page generated in 0.06706 seconds (68.62% PHP - 31.38% MySQL) with 11 queries |
