Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th November 2005, 03:05 AM   #11
Default progress!
I did some experimenting and found that if I leave the socket that's 2nd from the bottom empty, it works fine - pan works, solo button works, etc.
If I put chips into that socket I get all kinds of squealing and feedback when I adjust the pan pot. It seems to be associated with the echo send, echo pan controls, so no biggie, I just left them out and reassembled the board and now I'm in business with a stereo output.
Any idea why including those chips would cause the feedback problem? The power supplies look to be all in the same places... Maybe it's the echo part of the Master section?
Also, I have to keep the main stereo output set VERY low (like -45 db) or it hisses a lot. If I keep it down low and crank the individual channels I get a clean sound. But it seems weird that I would have to keep the mains so low to avoid hiss.
Looking for ultimate Chips for Home Theatre pra3718 Chip Amps 15 16th March 2009 01:40 PM
anyone ever built a tube mixer similar to the RCA Living Stereo type?? ncdrawl Tubes / Valves 12 23rd October 2008 06:13 PM
Can't get home built amp working ackeron42 Solid State 3 13th November 2006 06:35 PM
Has anyone built a high end DJ mixer? DJNUBZ Instruments and Amps 14 15th March 2005 08:04 PM
Built-in home entertainment SuppersReady Everything Else 23 12th November 2003 09:17 AM
Page generated in 0.06058 seconds (65.90% PHP - 34.10% MySQL) with 11 queries
