70's home-built mixer - please help me id missing chips! 70's home-built mixer - please help me id missing chips! - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th November 2005, 06:34 PM   #1
ultrajosh is offline ultrajosh  United States
Default 70's home-built mixer - please help me id missing chips!
I bought a home-built mixer on eBay, and it's pretty cool, built in the 70's. However, all of the channel strips are missing a few chips from the same 3 sockets. They seem to be associated with the Pan and Echo controls and the Solo/(pfl?) button. The rest of the strip (eq, compressor, buss assign) is populated with TL071's. Currently I can only use the top portion of the strips and send things out through the busses, but I want to use it as a full featured mixer (e.g. pan, stereo buss, etc).
http://www.ultrajosh.com/images/Home...ixer%20001.jpg
What is the best way to figure out what is supposed to go in here? What family of chips am I looking for?
http://www.ultrajosh.com/images/Home...ixer%20046.jpg
http://www.ultrajosh.com/images/Home...ixer%20045.jpg
Here's 1/2 of the monitor section:
http://www.ultrajosh.com/images/Home...ixer%20042.jpg
http://www.ultrajosh.com/images/Home...ixer%20047.jpg
- just stick in another 741?
Here's the master section:
http://www.ultrajosh.com/images/Home...ixer%20043.jpg
Any help hugely appreciated and I can some take better pics later...
Old 24th November 2005, 07:21 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hi ultrajosh and welcome,
It's hard to tell but I would take the risk with 741's or whatever might be in there in channel 16.
It's out now anyway and usually less used.
Nice website you have there. A lot on one page but informative and funny altogether.
/Hugo
Old 24th November 2005, 08:00 PM   #3
moamps is offline moamps  Croatia
First check that pins "7" ( and "4") are connected with one another.
Old 24th November 2005, 08:10 PM   #4
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
ultrajosh,
I don't think that it's a homebuilt mixer. It's probably a prototype of some product that was never produced.
As for the IC's. In the 1970's, the 1458 IC's were very popular.
What are the other IC's in nearby sockets?
This should give you a clue as to what goes into the empty sockets.
Frank
Old 24th November 2005, 10:35 PM   #5
The master channel is all 741's.
I originally tried TL071's in the empty sockets of the channel strips and got a high pitched rising squealing sound out of the stereo mains so I took 'em all out again.
If pins 7 and 4 are connected as in your diagram (haven't checked, yet) what would that indicate?
Old 24th November 2005, 10:47 PM   #6
You can insert then single opamps in that sockets (071, 741, 5534 etc.)
If "7" from 071 is connected to "8" on the empty socket, you should use double opams. Please, take better quality pictures of empty sockets area from the component and the track side.
Milan
Old 24th November 2005, 11:19 PM   #7
Thanks so much - I will take better pics tomorrow and post them...
Old 26th November 2005, 12:41 PM   #8
Default Better Pics
http://www.ultrajosh.com/tubeamp/Proto_Mixer/
Old 26th November 2005, 01:09 PM   #9
So there's (-) on pin 4 and (+) on pin 7 (if I'm looking at it right) on all the empty sockets, so it should take more 071's.
So maybe the feedback/squealing (oscillation?) is coming from the Master section? Or could that be caused by bad/fried chips somewhere?
Old 26th November 2005, 05:24 PM   #10
[B]So there's (-) on pin 4 and (+) on pin 7 (if I'm looking at it right) on all the empty sockets, so it should take more 071's.
You are right.
Did you check the group outputs? If the oscillation is there as well, the input module is faulty. I suggest you pull out all input modules except the one with the 071s inserted. Then you can check the signal routing to groups, pfl and master. When you make the console work with one input module, you can fix all the others easily.
Milan
70's home-built mixer - please help me id missing chips!Hide this!Advertise here!
Looking for ultimate Chips for Home Theatre pra3718 Chip Amps 15 16th March 2009 01:40 PM
anyone ever built a tube mixer similar to the RCA Living Stereo type?? ncdrawl Tubes / Valves 12 23rd October 2008 06:13 PM
Can't get home built amp working ackeron42 Solid State 3 13th November 2006 06:35 PM
Has anyone built a high end DJ mixer? JZatopa Instruments and Amps 14 15th March 2005 08:04 PM
Built-in home entertainment SuppersReady Everything Else 23 12th November 2003 09:17 AM
Copyright ©1999-2017 diyAudio
