help needed building a new brigde rectifier.... help needed building a new brigde rectifier.... - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd November 2005, 12:14 PM   #1
max29 is offline max29  Netherlands
Default help needed building a new brigde rectifier....
Need help for making a brigde or buying one somewhere.
Acoustic G100 gitar amplifier (4x6550 3x ecc 83 1x ecc 81) uses four diodes 1n4007 in a square soldered in series for rectifying.
Current is unstable though so needs replacement
Four freds would do or a bridge if existing ..
Are the Freds as easy to solder on to each other as these 1n4007 or is that all different
Where to get these.
Max29
Old 26th November 2005, 01:45 PM   #2
photo_marc is offline photo_marc  United States
I have soldered right to the pins on my projects. I bend the end of the lead over it self, form an eye with the wire to be joined and then I put them together and solder. The hole thing gets finished off with shrink wrap around the solder joints.
Be sure to use a BIG heat sink as this method takes lots of heat to get a good joint. I find a surgical clamp or small locking pliers work well
Hope this helps. You can see my project at [URL=http://www.diyaudio.com/forums/showthread.php?s=&threadid=68506]
help needed building a new brigde rectifier....Hide this!Advertise here!
Help needed building loudspeakers sogens Multi-Way 6 5th October 2007 07:11 AM
Aleph-X Building ( Comments Needed ) lscangus Pass Labs 9 21st February 2006 07:17 AM
schematic for dual output synchronous rectifier needed zilog Power Supplies 3 27th January 2006 06:32 AM
Help needed building a sub... gerbruggeman Subwoofers 10 3rd October 2003 01:43 PM
Building Rectifier Bridge with MUR 860 Lucas_G Pass Labs 5 20th August 2003 03:31 AM
Copyright ©1999-2017 diyAudio
