Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Best solder to use
Best solder to use
Old 19th November 2005, 06:31 AM   #1
rtarbell is offline rtarbell  United States
Default Best solder to use
I've never given a real thought to it... but what is the best valued solder that everyone likes? I just use Radioshack solder, but I haven't researched this topic.
Old 19th November 2005, 06:45 AM   #2
philibuster is offline philibuster  United States
lead free solder for the environment (and your health).
Old 19th November 2005, 08:22 AM   #3
R.I.P.
old fashioned 40/60 rosin cored cleans and sticks very well.
I have found some silver loaded also stick well if precleaned but I get the impression that the flux is not quite as good.
Lead free seems to introduce even more of the cleaning and sticking problems and for small scale amateur work is probably not a significant environmental issue.
If your soldering technique is below best then I recommend you stay 40/60
regards Andrew T.
Old 19th November 2005, 05:55 PM   #4
bigmike216 is offline bigmike216  Canada
I have 5 different rolls of solder on my bench.
A roll of good old Kester 44 60/40 is always on my desk. It's great for cables, and other bigger things.
I have a rool of kester with a water soluble flux. It's terrible, stay away.
Then I have several sizes of smaller diameter solders, all 63/37.. I do prefer 63/37 over 60/40. When it cools, thee's no pasty state inbetween liquid and solid with it, it just goes straight to solid. This is called a eutectic solder. .034 for through hole work, .020 and .015 or fine pitch surface mount work.
If you're doing surface mount soldering, I also suggest some liquid flux. It's an essential, and comes in convienient pen applicators. You can also buy it as lqiuid and put it into a squeeze bottle with a needle.
I'm not a fan of lead free solder. It takes alot more heat to melt, and really is a pain to work with.
Old 20th November 2005, 01:05 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
I use solder made by Philips.It definitely produces firm solder joint.But because it get "cold" a bit faster,cant work on"flood and heat up all pins"SMD desoldering methor.
Best solder to useHide this!Advertise here!
Fry Solder? jol50 Parts 0 25th November 2007 10:44 PM
what solder should be used ?? kambule Parts 27 8th August 2005 01:16 PM
can I solder on this? Duck-Twacy Multi-Way 9 24th February 2004 12:46 PM
how do you solder? theChris Equipment & Tools 15 2nd January 2003 10:55 AM
Solder again Christer Parts 13 6th December 2002 12:48 PM
