Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th November 2005, 02:41 PM   #1
Default parallel capacitors
Is it OK to parallel 2 600 VDC caps, I need 2.2uF 1200 VDC and really do not want to spend $43 a pop for 1200 VDC Mundorf SS caps.
Old 18th November 2005, 05:51 PM   #2
you need to add them together in series and use resistors to ensure equal sharing of the voltage.
I think using two 600V caps for 1200V is taking them too close to potential failure.
To get 2u2 1200V, you will need two 4u7 650V and that still leaves only a small margin for over voltage mains supply.
regards Andrew T.
linking capacitors in parallel - best practice jscherer Parts 8 17th March 2009 05:34 AM
parallel capacitors in PS question gary h Tubes / Valves 4 26th July 2008 09:06 AM
capacitors in parallel in a crossover Jonasa Multi-Way 3 6th January 2008 09:24 AM
parallel resistors / capacitors in crossover jimbo1968 Parts 4 26th January 2006 05:16 PM
Good or bad to use parallel capacitors of same value in signal path... 2004ex Tubes / Valves 1 25th May 2005 11:38 AM
Page generated in 0.05453 seconds (71.31% PHP - 28.69% MySQL) with 10 queries
