| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have read numerous safety notes about "if you unsure about making a power supply, then don't!" But I figured that there is a first time for everything. Anyway, I have all the bits together. My 500VA transformer is rated as follows: Prim: 2x115V Brown/White - Black/Pink Sec: 2x40V Red/Yellow - Blue/Grey * Because I'm in the UK (240V from the mains), I soldered the White and black together. * I wanted +-55V so I soldered Yellow and Blue together to be ground. * I soldered the Brown and Pink to the mains socket, via a 4A fuse and a switch * I soldered the Red and Grey to the AC sides of the 35A rectifier. * I didn't have enough solder for the caps, so I soldered two 33k resistors to the + and - of the rectifier to the Yellow/Blue * Nothing is touching the chassis. When I turned it on, there was nothing! I was expecting 57V (ish) AC from the rectifier, but the fuse had blown! This happens repeatedly! Any ideas?! I have included a picture to confuse you even more! Thanks Gaz |
#2 |
Guest
try taking the center tap off you you have 3: your CT your + and - and test from the + and - to eachother and from them to the CT you should get yes about 56V from - to + and your rated voltage from each one to the CT. It seems like your shorting the secondary (you don't need those resistors).
#3 |
Guest
or like this
#4 |
Banned
Is this a brand new transofmer and are you ataching the ac to them main ins not the secondary's ive seen people do that.. and desconect your brige and look for straigt ac.
#5 |
Banned
#6 |
Do you have the CT and the main grounded to the chassis? Your using a 240V 4A fuse right?
#7 |
Banned
Humm.. yuo should try what i said.. too..
#8 |
OK, thanks for the great response! * Nothing is touching the chassis nor Earth. Just Live and Neutral. * The fuse was rated at 250V 4A. Ceramic type. * All testing must stop until tomorrow when I get new fuses! * The reason I put the resistors there was so that it would pull a current, albeit under 50mA. I thought power supplies overloaded without a load. * I did try without the resistors first, but the same thing happened. It is a brand new xformer and I'm sure that it all connected the right way around. Gaz |
#9 |
Banned
you should doubble cheak the wireing man..
#10 |
Hi.
I have the amp here on my lap (it has bass isolation spikes from a loud speaker attached to the bottom, so with the weight of the heatsinks and xformer, it is quite painful!) I have taken off the resistors, and will get some fuses tomorrow. The wiring is correct according to your suggestions. The only thing I can think of is that it is dependant on the polarity of the mains in...but it is AC, it shouldn't matter! There are no short circuits... I can't even take pictures for u to look at until the 8th Nov when I give my GF a digital camera for her bday! Gaz |
| Keep Blowing Fuses | Whiting | Tubes / Valves | 9 | 11th September 2008 09:44 PM |
| Car Amp help? Fuses blowing... | Tolo | Car Audio | 1 | 3rd December 2007 01:42 PM |
| Blowing fuses | balance | Tubes / Valves | 2 | 5th March 2005 02:16 AM |
| blowing fuses | homegrown45167 | Car Audio | 2 | 22nd October 2004 12:16 PM |
| The Fuses Just Keep Blowing | raffir | Chip Amps | 19 | 22nd June 2003 03:49 AM |
