Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Why does my PSU KEEP blowing fuses?!
Old 15th October 2002, 03:36 PM   #21
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Why does my PSU KEEP blowing fuses?!
Thanks for all your help!
I think I may have sorted it though. It seems that not all ceramic fuses are slow blow. In fact these were positively quick blow!
I am buying some tonight. Along with some decent solder. I bought some the other day and I had about as much success melting it as trying to melt a spanner in your mouth!
I'll let you know...
Gaz
Old 15th October 2002, 06:33 PM   #22
Rarkov's Avatar
Well I got the new fuses. I put them in with high hopes...
The fuse came out as though a bomb had been let off in it! There was molten balls of metal all over the glass. The glass was cracked and all charred! What the hell is wrong with this thing?!
I'm going to try changing the wiring...
Gaz
Old 15th October 2002, 06:40 PM   #23
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
take off every thing yuo have atached to the transformer that means cap resisters brge rectifiers. ect ect then test it. go to the manufactures website about the wireing.
Ceriouse what kinda to you have..?
Old 15th October 2002, 06:44 PM   #24
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Sounds like the transfomer has internal shorts, and so is probably FUBAR!!
Check the resistance of the taps on the input side, (and output side) and see if there are any relative differences, if so, see the above!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 15th October 2002, 06:54 PM   #25
Banned
I was thinking the same thing if it so you should contact the manufacture an tell them you have a brand new ( if it is brandnew ) psu and it is shorted mabey buy shipping..
Old 15th October 2002, 06:54 PM   #26
Rarkov's Avatar
I've located the problem...We're all wrong!
It was the bridge rectifier. I got a continuity test on it. There was contact from + to AC on the knackered one and no contact between any pins on the good one. Seems that the diodes blew up...(reverse voltage?!)
So, why isn't my BR working?!
Edit:
I checked the output from the Xformer with the secondary taps disconnected and without the BR...44V RMS on each
Thanks,
Gaz
Old 15th October 2002, 06:59 PM   #27
phase_accurate is offline phase_accurate
Hi Rarkov
First of all disconnect everything on the secondary just to make sure that the problem isn't caused there - as Jason suggests - before making further tests.
Are you sure that you wired the primary windings with the right phase (as others mentioned above) ? Otherwise the transformer will indeed act like a short-circuit. Maybe you should try to connect one of the primaries the other way around. Before firing it up connect a light-bulb in series with the primary (40 to 60 Watts). If everything is O.K. you will measure almost the nominal output voltage (under idle condition !!) with the lightbulb glowing just a little. If the lightbulb is illuminated then there is still a short somewhere. Maybe you killed your transformer, but I don't think so since transformers belong to the sturdiest components and can bear some abuse.
Charles
Old 15th October 2002, 07:04 PM   #28
Banned
i new it was the bridge rectifier. it is like a dead short. i've been there done that many times.. like my dad alsways tells me start at the simplest point work your way up remove all the things and test one at a time. ex
tx > bridge > then caps > then wire >
Old 16th October 2002, 05:28 PM   #29
Rarkov's Avatar
Success!
I have found the problem. The diode between +ve and AC on the bridge rectifier was fried (but internal so was not noticed). The must have short circuited it an overloaded the fuse. Even after replacing the BR though (and wiring up the Caps) the fuse would still blow. I replaced the Slow Blow 2A fuse with a SW 5A fuse and all is well. I have a very stable +- 61.3V!!! Thanks so much!
You've also helped almost clear my fobia of PSUs...One thing though...One of the solder contacts came off the cap whilst it was charged...When it came into contact there was an almighty spark...I want to drain the charge when not in use. What resistors do I need?!
Thanks,
Gaz
Old 17th October 2002, 03:35 AM   #30
CryingDragon
Guest
I'd say 10K 1 watt for bleeding.
Why does my PSU KEEP blowing fuses?!Hide this!Advertise here!
Keep Blowing Fuses Whiting Tubes / Valves 9 11th September 2008 09:44 PM
Car Amp help? Fuses blowing... Tolo Car Audio 1 3rd December 2007 01:42 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 12:16 PM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 03:49 AM
Copyright ©1999-2017 diyAudio
