| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#51 |
Hi, I know bringing a thread from the dead
but I have a question? If I replace a higher rated output transistor inplace a of a lower power rated one? I put in C3856 and A1692 inplace of C4467 and A1694 because they were the only transistors I had. It plays good the receiver haven't had a problem so far. Any idea if it's good?
Feel the PUNCH |
#52 |
Should be ok, depends on the circuit topology. The fT's and gains are within reason (well except the bigger transistor goes to a higher current as expected) and SOA is larger, so you shouldn't have too many issues if the output stage was an EF.
CFP on the other hand could cause issues with oscillation. |
#53 | |
Oh yeah the model of my receiver is KR-A4040
Feel the PUNCH |
#54 |
Hello to all of the forum to replace these transistors it is D1047, B817 ok up to soon.....
| Replacement for Sanken A1186/C2837 | CBRworm | Solid State | 14 | 11th April 2010 12:31 PM |
| SanKen transistors (A1492 & C4883A) | PCForrest | Parts | 3 | 1st June 2008 10:40 AM |
| Transistor replacement | Mlaen | Solid State | 3 | 18th February 2005 11:00 AM |
| sanken 2sd123 replacement?? | THENIGHTFLY | Solid State | 2 | 30th January 2004 04:41 PM |
| Sanken Transistor | halvardf | Solid State | 15 | 15th September 2002 11:14 PM |
