| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am not sure if I remember correctly (knew this kind of stuff as a kid), but is the short leg on the LED the cathode (which goes to negative power rail).
Lol we had this crazy teacher, he explained to us the diffirence between anabolic and catabolic drugs, so he said, to remember which is which, think of a cat which claws things, as a breaking down process (sorry badly translated it all happened in my home language)... this image stuck till today so I know cathode is negative cause it has a cat in. LOL No point knowing this if you still don't know which leg is supposed to signify which polarity. |
#2 |
The short leg is more negative when the diode is conducting. That may or may not be because of a connection to a negative rail, just so long as the longer leg is more positive than the shorter.
I never remember this, so I just use an ohmmeter before installing the diode.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
The short leg side (cathode) of 3mm and 5 mm LED packages has a flat molded into the package. It is hard to see unless you look closely, but you can feel it with your finger. Think of the diode schematic symbol, and that flat as the cathode.
If you have trouble remembering which end should be more positive, use the diode symbol. The diode symbol has a triangle as an arrow-head to point in the direction of current flow. Current flows from a more positive point to a more negative point, in the direction of the arrow. It took me a long time to get used to engineers thinking current flows from anode to cathode, when the majority of carriers in conductors are electrons and the flow of electrons is what constitutes current- in the opposite direction! If you think about vacuum tubes, the electrons flow from the cathode to the anode- they can't go the other way! For some reason, a long time ago, someone (Ampere?) decided that current flow went from + to - even though that is opposite the physical process, except for the microscopic region in semiconductors where "hole" flow is the majority carrier (in which case current does move in the same direction as the carriers). Electrons don't actually flow, either, the way water goes through a pipe. They are displaced by other electrons. One electron in a wire doesn't typically move down the length of the wire at nearly the speed of light. It moves a short distance (a few inches), at the drift velocity, which varies with the material, and is considerably slower than the speed of light. If the drift velocity is so slow, how can electric current move at (or near) the speed of light? When the power switch is closed, an EM field is established at the speed of light, moving all the electrons in the circuit very nearly simultaneously. I_F |
#4 | |
Lacking any means to measure ther direction of the flow he guessed. The chances of getting it right were 50-50 and he got it wrong. If he had gotten it write historians of science would write learned essays trying to determine how he did it. |
| Quick question on the PP-C1 amp | athos56 | Tubes / Valves | 13 | 20th October 2007 06:37 PM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| Quick PCB question | Piper | Chip Amps | 2 | 7th March 2005 10:59 AM |
| VERY quick question... | Wyloch | Multi-Way | 2 | 3rd March 2005 04:34 PM |
| Page generated in 0.08880 seconds (77.30% PHP - 22.70% MySQL) with 10 queries |
