Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th November 2005, 09:37 PM   #1
kepa1 is offline kepa1  France
Question Is it ok...
... If i connect four caps on a bridge rectifier and their pins have contact with each other?
Plus, I inserted and soldered the caps pins to the holes of the rectifier connectors, does it sound allright?
These are my newb questions!
Old 13th November 2005, 10:45 PM   #2
pinkmouse's Avatar
Hi Kepa1
It sounds ok, but could you post a pic or drawing so we can make sure for you?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 13th November 2005, 10:54 PM   #3
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Sounds feasible.
You're thinking of connecting these four capacitors directly to the rectifier I take it?
Should be fine; but a picture helps us help you.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 14th November 2005, 09:29 AM   #4
Thanx guys, the photo is on its way for tonight!
Old 14th November 2005, 05:54 PM   #5
Back home, so here is the photo:
You can see these four caps around the left bridge, each rectifier being bypassed and eventually all caps being connected to each other through the rectifier pins. I've seen it before on the net but it just feels curious because current should go from one cap to another, causing a short circuit or something similar, shouldn't it?
Now I feel more ashamed to ask this question...
Old 14th November 2005, 06:04 PM   #6
Just to complete the picture you could add spike supression caps diagonally across the corners pins. i.e. across the AC input and across the DC output.
If you draw the schematic it is quite normal. It's just that everyone else is so used to using PCB and forgotten about hardwiring but without the wires.
Some are advocating the use of snubbers (series resistor & cap) across each of the diodes instead of just a cap. They claim it reduces the Hi. Freq. hash that would otherwise get sent to the smoothing caps and then only partially attenuated goes into the amplifier or other downstream client.
regards Andrew T.
Old 15th November 2005, 01:09 PM   #7
Thank you for the tips AndrewT, maybe there is room enough!
But does your answer mean that the set up on the photo is Ok...?
Old 15th November 2005, 02:47 PM   #8
YES
regards Andrew T.
Old 16th November 2005, 09:57 AM   #9
pinkmouse's Avatar
I agree!
Al
Old 16th November 2005, 07:10 PM   #10
Job done, thank you guys!
But it wasn't an easy one, the bridge pins don't like solder at all, I mean it's like rain drops on the window pane...
And hard wiring a potentiometer isn't funny either
I guess It's were PCB makes sense!
Page generated in 0.09264 seconds (77.74% PHP - 22.26% MySQL) with 9 queries
