Oscilloscope problem Oscilloscope problem - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th November 2005, 08:28 AM   #1
Alien8 is offline Alien8  Belgium
Unhappy Oscilloscope problem
Hi
I think I've managed to 'hurt' my tektronix 485 scope. The symptom that is showing is whatever is present on one channel, also shows up on the other one. So channelseparation would be zero (?)
At first I thought it could be just a mechanical problem with the switches for the vertical mode. After all this piece is over 30 yrs old !
So I opened it up and tried to see if I could get to those switches, unfortunately they are buried under the input dividers. And I can't get to them.
Upon inspection of the other pcb's I noticed an overheated resistor (showing burn marks) and a broken capacitor next to it on the power supply board, next to one of the connectors that connect to the vertical divider boards. I would think that that resistor is for PSU decoupling of a +15V line.
When I started thinking what might have caused this, it is possible that I had both probe grounds connected to a differential voltage point of 6V, unfortunately by a high current battery in between. Or, connected to the ground input of my spectrum analyzer ???
Can somebody point me in the right direction ? I sure would like to have this problem fixed if possible. Any one knows somebody in Belgium that can still service these tektronix scopes ?
TIA
A8
If 'I' knew what I was doing, life would sure be easier...
Old 13th November 2005, 08:47 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
This is about the only info I have for the Benelux:
I'm not sure its accurate but worth a try.
TEKTRONIX HOLLAND BV
POSTBUS 226
2130 AE HOOFDDORP
+312503-13300
TEKTRONIX
POSTBUS 406
2130 AC HOOFDDORP
+3123-5695555
/Hugo
Oscilloscope problemHide this!Advertise here!
Oscilloscope Channel 1 problem on BK Precision model 2120 albertho Parts 2 24th January 2017 04:33 PM
A problem with my oscilloscope gaetan8888 Equipment & Tools 1 13th August 2007 11:41 AM
Oscilloscope use. argonrepublic Parts 1 21st January 2006 07:00 AM
PC or USB Oscilloscope owel Parts 9 31st March 2004 08:55 PM
Oscilloscope anybody? nitropowered Swap Meet 5 24th July 2002 03:14 PM
Copyright ©1999-2017 diyAudio
