| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
any information about those transistors or substitutes Sanken (?) Seem to have been used in Pioneer M25 amp. |
#2 |
Not likely.
MN25 was a TO3 germanium transistor made by Motorola. MP25 a Russian made TO5 device (ELORG= elektron org. teknika in Moscow) MN25 and MP25 were probably the internal Pioneer device numbers, M25 NPN and M25 PNP. Only ones producing ringemitters were Toshiba and Sanken, production of high power ringemitter transistors started before Pioneer started production of the M25 in '79. Later production Toshiba ringemitters had the identical MT200 casing and color as Sanken devices. Pioneer produced the open-style chassis 30 watt class A M22 end of the 70s, followed-up by the partial class A M25. Both looked practically identical, seen quite a few of these machines in France. www.visi.com/~jweeks/stuff/pioneer/#series20
Looks like Sponge Bob has killed another thread. |
#3 |
Thanks,
the matter is, if I get a broken M25 and need to replace output RETs, is there a possibility to get those or use Toshibas or Sankens ? |
#4 |
The ringemitter devices used in the M25 and A27 integrated amplifier were TO3 models.
Fat chance that you can find those, MT200 Sanken's will have to do. Means redrilling the sinks with the MT200 pattern.
#5 |
Here is a picture of the output section of the A-27 integrated amplifier model (found it on a Pioneer series homepage somewhere)
2 NPN and 2 PNP TO3's per channel. Supposedly the A-27 used the same devices as the M25 did, and much of the circuit concepts of the M25 and C21 preamplifier. Pioneer used the big casing Sanken multi-emitter devices in the later M series power amplifiers.
#6 |
Later model multi-emitter devices
#7 |
revised casing Toshiba ret's
#8 |
Thanks, so I have to look for a A27.
Your first picture does not load completely. |
#9 |
found the homepage i got the picture from again:
http://www.silverpioneer.netfirms.com/a27_amplifier.htm These amplifiers have collectors value, and you would probably need 2 of the A-27 amplifiers to have enough output devices to repair an M25. Fixing an M25 with modern Sanken devices will not keep the amplifier original, but a lot easier and big Sankens are very rugged. The M model is a lovely design, wouldn't mind having one myself.
#10 |
Just got the amp and - huh - all output transistors measure around 0,5 V from case to one pin and another 0,5 V between pins with diode tester.
| motorola dcp501 | thuthriller | Class D | 313 | 15th March 2012 11:18 AM |
| Motorola OPT | alejo | Tubes / Valves | 0 | 4th April 2008 07:50 PM |
| The ID CD1.E... A Motorola right? | Tuukka | Car Audio | 0 | 17th February 2007 12:52 AM |
| WTB: Motorola DCP-501 reciever | DcibeL | Swap Meet | 3 | 11th October 2006 05:27 PM |
| Motorola Fet | AR1 | Parts | 10 | 10th June 2005 04:49 PM |
| Page generated in 0.09309 seconds (79.27% PHP - 20.73% MySQL) with 11 queries |
