Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Transistor Tester Current Levels
Old 15th December 2005, 12:04 AM   #21
Stocker is offline Stocker  United States
What, was this in a newspaper or something? More people paying attention, wow!
Goals re: features:
Simultaneous display of Vbe Ic and Ib
Switchable current ranges for Ic
Adjustable current for Ib (currently 2 ranges)
Test NPN, PNP and N & Pch. FETs
DC testing
AC testing looking like it will make the list thanks to the recent blessing of a free O'scope (thanks, God)
Protection for the panel meters is intended to be limited by the voltage of the supply... about 12V is all it will have to give, which with the current resistors is safe for a 1.99 (or 1.999) volt meter. That is a good point though. Perhaps the circuit just got a bit more complicated, I'll have to think about it some. Currently, there are some low-noise buffers planned to isolate the test from the meters. Clamping the output shouldn't be too hard.
As for selecting Vce, it sort-of just happens with this design and I'm hard-pressed to think why I would want to monitor it, seeing it's to be a direct relationship with the Ic reading.
peranders, jackinnj has it right with my motivations for building this unit.... DIYAudio is the name of the board... matched components baby. You do raise a different point tangentially: This is not going to be a tester to determine what a device is, as I don't plan on using unknown devices in my DIY Audio kit. Datasheets only get you so far. Then we need some actual numbers
Thanks guys, keep it coming. Jackinnj I'll have to peruse that article after work.
Jesus loves you.
Old 15th December 2005, 05:08 AM   #22
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by Stocker
peranders, jackinnj has it right with my motivations for building this unit.... DIYAudio is the name of the board... matched components baby. You do raise a different point tangentially: This is not going to be a tester to determine what a device is, as I don't plan on using unknown devices in my DIY Audio kit. Datasheets only get you so far. Then we need some actual numbers.
If you have made a good design no part have to be matched, possible the input stage. When you design you use worst case values of critical parameters. If the Hfe is 300 typical and min 150 you take 50-100 as a working value.
If you of some reason do want to match do it in the real stage. Mount a socket and change only one transistor. Note the offset (or whatever) on each transistor. Two transistors with the same offset are probably alike. Building a real transistor tester is a massive overkill. I had a curve tracer long time ago. It was very neat but it was more for checking possible broken transistors.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 35 pcb's in interest.
Old 15th December 2005, 09:20 PM   #23
To each his own. Perhaps Pass would have a thing to say about optimal designs not requiring matched devices? There are several amplifiers I would like to build that require matching for low DC offset at the very least. Besides, aside from the effort, why *not* build it? It has already been a learning experience.
Jesus loves you.
Old 16th December 2005, 07:08 AM   #24
R.I.P.
Peranders,
your worst case is only considering lowest gain.
For some performance specs, a worst case would be when one Q is lowest gain and the other Q is highest gain.
The spread in parameters is the problem.
Stocker,
if you see a performance improvement by matching transistors come back and report your results. I suspect it will mirror the results achieved by many others.
As an aside D. Self published measured voltages and estimated currents on an LTP front end with almost matching transistors. He particularly drew our attention to input bias current and input offset and how it flowed to the output, but could not be corrected by NFB
regards Andrew T.
Old 18th December 2005, 06:01 AM   #25
Thanks for the encouragement guys. I stayed up and did some calculating last night; hopefully I will complete this thing within the year (note, this is the 2nd year of 'construction'! )
As for improvements, I am hoping there will be none: I aim to build my stuff one time (ha, as if it were possible) and build it as well as I can that once. You all may note from paragraph one of this post that I like to take my time... hopefully this contributes to the best result possible!
Thanks,
David
Jesus loves you.
Old 20th December 2005, 07:13 PM   #26
jackinnj is online now jackinnj  United States
jackinnj's Avatar
here's the Tester using the Measurement Computing USB-1208FS -- on a protoboard -- an LM317 was used to set collector current to 10mA -- for BJT's values of R can be adjusted between output and adjust to set the current from 100uA to 1A -- with the drop-down list. Sorry, I haven't yet completed the MU test for FETs.
I reworked the graphical user interface to be a lot simpler -- just press the button to switch between FET or BJT -- anyone who purchases one of these MCC devices and would like the code just send an email and I'll send a zip file back.
Old 21st December 2005, 05:28 AM   #27
Hey that's pretty sweet for low current testing. Try to get 40W into an output device with it tho!
Jesus loves you.
Old 27th December 2005, 10:34 PM   #28
anatech is offline anatech  Canada
anatech's Avatar
Hi Stocker,
I normally use a Heathkit IT-18 for testing. Jigs for matching power transistors.
I'm watching your thread.
-Chris
Old 27th December 2005, 11:46 PM   #29
Ah well, since you're watching, I'll update.
I have been pondering numbers and I am -->.<-- this close to putting parts together. I just need a few clear hours at a stretch with nothing else to do...with a job, wife, kids, dogs, house etc. you can see the hours are few/far between. I have been making slow progress though. The 3rd panel meter has been modified to fit the chassis. The wiring needs to be ironed out. I need to select the actual switches that I will use. I will make a temporary final schematic and wire up a test to see if the circuit is valid.
Big Brother is watching also.
Hello, Echelon.
Jesus loves you.
Old 28th December 2005, 12:15 AM   #30
anatech's Avatar
Hi Stocker,
Should be interesting to see what you end up with. Since you're a calibration tech like I was, I'll give you a list of equipment I use when you are done. It would be nice to be able to match outputs in banks instead of onesy-twosy.
-Chris
Transistor Tester Current LevelsHide this!Advertise here!
2 transistor current source Omicron Parts 16 22nd February 2006 09:02 AM
LM317 with a parallel transistor for current? Progg70 Power Supplies 2 31st August 2005 05:01 PM
too much current thru transistor xplod1236 Parts 27 29th May 2004 04:09 AM
transistor tester janey Solid State 0 4th January 2002 02:44 PM
