| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello
I use eagle, and want to send gerber files to www.4pcb.com Can any one please guide me to which required ULPs and CAM jobs I have to use, also which layer to check when producing the gerber files for each job. If possible may be some one can post pics of the necessary steps while working on eagle. Thanks |
#2 |
Need a bit more info on your board first. Could you post a pic? Don't worry about ULPs, you just need the Cam processor.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
1. Run drlcfg.ulp first
2. In EAGLE open the File Menu goto the CAM Processor 3. In the CAM Processor goto File | Open | Job... 4. Open Excellon.cam 5. Process Job 6. Open Gerb274x.cam 7. Process Job 8. The following files should be generated: *.drl *.drd *.sol *.cmp *.stc *.sts *.dim *.plc 9. Use a Gerber viewer like GC-Preview from GraphiCode and check your files (import them into GC Preview) 10. Make a zip file from the data and send them to your prefered pcb supplier. |
#4 |
thanx guys
I appreciate that in deed. bye |
#5 |
I was going to advise depending on what layers, etc. you were using, but if it's a double sided board, then just go with Bocka's method. If that doesn't work, then go with the mail thing and I'll have a look.
#6 |
Hello pinkmouse, and hello all
You seem to be a well experienced in gerber, any way, I have followed what bocka said, and genearated the files to upload them here on the forum, so that pinkmouse and bocka can comment on them. I am making this PCB as single layer, when I opened the CAM processor, I used Excellon job, and choose the Gerber RS274-X as the device, to generate the drill file. After that I choose the Gerber RS274-X job,and choose the Gerber RS274-X as the device to genearate the rest of the files. For the CMP file, I only choose the pads to show on the top components side in case of single sided PCB, I think this is not really necessary. I also used GerberTool v14.2 to import the the files, and generate one gerber file, which is also included in the zip file. Any way, please correct me if I am wrong here: 1. For .cmp file, component side, if I am making double sided, then I have to choose pads, vias, and top layers. If I am making single sided PCB, then I will leave this without choosing any layer. 2. For the .sol file, solder mask, I have to choose pads, vias, and bottom layers. 3. For .plc file, silk screen, I only show dimension, tplace, tnames, and tvalues. 4. For .stc file, solder stop mask"From component side" I choose tstop. 5. For .sts file, solder stop mask"From solder side" I choose bstop. Any way, I have uploaded all files generated by the CAM processor, and also made .PNG images for guys who can't view gerber or other files. Thanks in advance |
#7 |
Hi again
Here are the .PNG images... |
#8 |
On a quick view it looks fine. Don't forget to make a readme file where you specify the layer assignments. If there is missing something the pcb manufacturer will contact you. Good luck!
#9 |
Hello
There are many mistakes in these files, I have discovered that the files of .stc, sts, and .plc are not consistent, I mean if you try to view .plc, and .sts, you will note that pads and components are not aligned the right way. I tried to find out why is that, but no way guys, if you try to open them with any viewer, you will note this. I don't know the reason for that, even though, I read the appendix again and agian in eagle manual to see if I used the wrong layers for each file, but they all seem right. Can any body explain whats happening here... Thanks |
#10 |
Beware of the Mirror settings in the CAM processor...
| Eagle drillfile/gerber creation | skrodahl | Parts | 4 | 2nd December 2008 07:20 PM |
| Eagle: Mirror bottom layer for Gerber files? | orthoefer | Everything Else | 4 | 17th August 2006 12:38 AM |
| Question about Eagle and Gerber-files... | CJ900RR | Everything Else | 2 | 9th August 2006 12:08 AM |
| Gerber help on Mac OSX | pinkmouse | Everything Else | 4 | 3rd May 2005 02:38 PM |
| Page generated in 0.09936 seconds (81.32% PHP - 18.68% MySQL) with 11 queries |
