Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
resistor comparison test - tantalum?
Old 4th February 2003, 09:08 PM   #101
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default VISHAY.
Vishay make a wide range of resistors,the S102 range AKA bulkfoils are the better sounding ones.
By which I don't mean to say the Rikken are bad,I would use them in different places as I would the bulkfoils though.
Vishay VTA55: sounded laid back, sort of mellow, darker in character, tubelike with midrange in the first plan
That decription would fit the Holco H range IME. (the non-magnetic ones,that is).
Frank
Old 4th February 2003, 09:16 PM   #102
dorkus is offline dorkus  United States
dorkus's Avatar
Send a message via AIM to dorkus
Default Re: VISHAY.
really? i actually find Holco H4's to be a little cool-sounding.
Old 4th February 2003, 09:27 PM   #103
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
resistor comparison test - tantalum? Send a message via AIM to Peter Daniel
Originally posted by fmak
You need to repeat with resistors in both directions. Can make a big difference. I tried Vishay and Rikken in passive preamp mounted in opposite directions. I prefer the Vishay . Direction makes the difference in terms of sonic balance.
You must be kidding me. I have already enough of directivness in capacitors.
Is the lettering or color coding at least consistent with a direction? So what are the major differences?
To order kits contact me through forum mail.
Old 4th February 2003, 09:38 PM   #104
fdegrove's Avatar
Default HOLCO
Dorkus,
Good to see familiar names again.
All I can say is that these Holcos (H4 and H2 range) replaced Roederstein Resistas for anode Rs,cathode Rs and gridleak Rs in my own gear from preamp to amps up.
I found the result rather too lush and dark sounding compared to what I was used to hear.
Frank
Old 4th February 2003, 09:44 PM   #105
jcarr is offline jcarr  United States
Elso: Processing can make a large difference. For example, you can take the same semiconductor die, put it into a different package, and the sound will be quite different.
OTOH, if you didn't hear any difference between a standard metal-film resistor and a VSH, I would just forget about it. No matter how wonderful other builders may claim certain components are, if you can't make them work to your advantage and your tastes, you are better off focusing on the aspects and components that result in sonic benefits for _your_ circuits and _your_ tastes. No sense in cluttering up your life with details that you cannot take advantage of.
Frank:
>The Vishay S102 bulkfoils have a rep for sounding as close to no resistor at all.<
I reckon that the S102s _do_ have a distinctive sound. In fact, there are quite a few Japanese builders that don't like the S102s. If nothing else, this demonstrates again that no single component is suitable for all tastes and all circuits.
>I don't mean to say the Rikken are bad, I would use them in different places as I would the bulkfoils though.<
I completely agree. Both sound (and measure) quite differently, and for different reasons, both are useful for audio circuits.
regards, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 4th February 2003, 10:01 PM   #106
fdegrove's Avatar
Default DIRECTIVE RESISTORS.
Ahem...if they're not than we have ourselves a little problem...
And I'm pretty certain no manufacture of ressitors care about directive of their elements and leadout wires.
The good news is that after burn in it really doesn't matter.
This is not the case with filmcaps however!
Jonathan,
You're absolutely correct,they do have a sound of their own.
What doesn't?
Still as a series R they seem to exhibit more neutrality than anything else I tried so far.
I still need to put the "nudes" to test though...
If you have other Rs in mind worth trying,I'd sure love to give them a try.
All,
For those of you working with voltages higher than say your regular transistor amp the voltage rating and wattage of these resistors have to be kept in mind.
Not to mention the self inductance of wirewound resistors where none inductive ones (a la Ayrton Perry windings) are to be preferred.
Frank
Old 4th February 2003, 10:09 PM   #107
Jonathan,
That is actually a question I was thinking about asking before. What is your experience with directivity in resistors?
Old 4th February 2003, 10:16 PM   #108
frank:
>They seem to exhibit more neutrality than anything else I tried so far.<
Emphasis on "so far".
>I still need to put the "nudes" to test though...<
If you can obtain and compare identical values of S102s and TX2352s, it will be interesting to compare our respective impressions.
Old 5th February 2003, 12:26 AM   #109
fdegrove's Avatar
Default "NUDES"
Rest assured,I will.
In the mean time I welcome any brand/type suggestions worth trying.
Frank
Old 5th February 2003, 07:23 AM   #110
fmak is offline fmak
Why don't you try it and then decide if I am kidding you. For critical use, I actually try in both directions. Labelling is a different issue which you have to determine from batch to batch. There is a bigger consistent difference in resistors than capacitors, at least without burn in. I have not so far considered the effect of burn in.
If you have this kind of attitude to comments by others, why should other people believe your observations?
resistor comparison test - tantalum?Hide this!Advertise here!
Audio Note Tantalum Resistor (1%) US$3 each. Worth using it loong Chip Amps 10 17th August 2016 06:48 AM
Shinkoh Tantalum resistor naimgame Parts 1 16th June 2008 09:09 AM
Re-starting test and comparison activities, now an AKSA new model arrived, also a new destroyer X Solid State 2 18th June 2006 11:20 AM
Aleph 2 source resistor comparison? tomchaoda Pass Labs 11 19th July 2004 06:20 PM
