| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I always wanted to know: fuses blow based on the current that is being drawn through them
==> why do fuses have voltage ratings? |
#2 |
Hi rtarbell,
That's an easy one to answer. While the fuse is blowing, it has to interrupt the current flow. There is sometimes an arc to quench. The applied voltage, if too high, may continue to arc. At the very least, the current is not interrupted in the time specified for that fuse. Ever price out 600V fuses? Ouch! -Chris |
#3 |
BTW, it's not always appreciated that most fuses are rated at their maximum continuous current - the rupture current is often appreciably higher.
#4 |
Hi dnsey,
Correct. They are rated at the current that they will blow at in X amount of time. It is a temperature vs time thing. There are also time rating at 200% of current and others. The length of time to blow will surprise you. -Chris |
#5 | |
------ One rating more for fuses is max amperage breaking capacity, if you use normal small glass tube in 300v circuit with short-circuit current of 15kA it wont behave as fuse anymore.. No need to care about this normally, exept when buying those !#¤%"#¤ expensive fuses for your Fluke. |
#6 |
Yes that time delay on rupturing is very fortunate. It allows the output transistors enough time to protect the fuses and save having to replace them too often. More sensibly use T fuses on the mains side to prevent spurious blowing at switch on, F fuses after the smoothing caps and do not fuse the speaker leads.
regards Andrew T. |
#7 | |
Or buy ultrafast semiconductor fuses, tough they may cost more than your output transistors |
#8 | |
I feel the transistors short to ensure the fuses blow. That way you can't sue the fuse manufacturer! -Chris |
| nad 214 where are the fuses? | gregkitchen | Solid State | 1 | 18th August 2006 11:35 PM |
| Why are these fuses blowing | Darin P-B | Solid State | 41 | 30th May 2005 10:56 PM |
| blowing fuses | homegrown45167 | Car Audio | 2 | 22nd October 2004 12:16 PM |
| Why does my PSU KEEP blowing fuses?! | Rarkov | Parts | 29 | 17th October 2002 03:35 AM |
| Page generated in 0.07767 seconds (84.01% PHP - 15.99% MySQL) with 10 queries |
