Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th November 2005, 01:43 PM   #1
Default mounting bolt = min pole?
Maybe a noob questions that has been asked 100 times before (but I couldnt find it)
I noticed that the M12 mountingbolts of my Rifa PEH169 caps are actually electrically connected to the minus pole of the capacitor. I am bolting these caps on a aluminium chassis of the amp. Can this cause problems???
Of course the minus pole will be connected to ground anyway, but can having the mounting bolt also touch the chassis in some way be harmfull (for people or for the amp)? Its for a Zappulse pwm amp btw.
Btw I have these nylon mounting nuts, but in order to make them isolate I have to make the holes for the mountingbolts 22.5 mm wide. Then the nylon caps canl recede 1 mm into the chassisplate
http://www.elfa.se/pdf/67/06767461.pdf
http://www.elfa.se/pdf/67/06768303.pdf
http://www.svalander.se/shoppen/pdf/...c_appguide.pdf
Is that all there is?
Old 6th November 2005, 06:35 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
You should isolate the mounting bolts....
First of all because this extra connection could cause a ground loop in single rail amplifiers.
Worse is it in two rail amplifiers (positive and negative supply rails). In the possitive rail, the mounting bolt will be "ground", but in the negative rail, the bolt will be = negative supply. Ground and negative supply connected together = trouble
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 6th November 2005, 07:19 PM   #3
THanx for your reply. I will adapt the holes, so that the nylon cap nuts can be used to isolate the mountingbolds from the chassis.
Old 7th November 2005, 08:27 AM   #4
is the can connection to negative of the cap a common occurence?
I always thought the can was insulated from the cap and would only conduct if there was a catastrophic failure.
Do you need to bolt the can to the chassis? Try silicone sealer as a glue/insulator. It sticks well to metal work.
regards Andrew T.
Old 7th November 2005, 03:24 PM   #5
Jan Dupont's Avatar
Normally when the caps are with screw connection, the can it self is isolated
Withworth bolt for AR3a? KJ2005 Multi-Way 4 9th November 2008 08:51 PM
How To Cut A Nylon Bolt? kelticwizard The Lounge 4 31st May 2008 05:20 PM
Toroid bolt clearance cpemma Power Supplies 10 26th May 2006 06:56 AM
Mounting toroids with little to no room for bolt ThingyNess Parts 24 27th February 2003 07:54 AM
Page generated in 0.07729 seconds (72.49% PHP - 27.51% MySQL) with 10 queries
