Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th November 2005, 09:06 PM   #1
Default crackling sound CDM 4
I have a problem with my CD player. It is a CDM4/31 type mounted in B&O Beocenter 8000.
It plays perfectly for apporx. 30 minutes. After that the sound distorts and crackling sound occurs.
Does anyboy have an idea wht the problem can be?
Thanks,
Thomas
Old 4th November 2005, 09:26 PM   #2
karma is offline karma  Canada
karma's Avatar
run the cd player with the lid off and run it to see if it runs longer.
rule out a ic overheating or failing when it warms up.
voltage regulator?
bad caps?
its a start
Old 5th November 2005, 11:22 AM   #3
hacknet is offline hacknet  Singapore
i had problems like that with my cdm4 when the lens got dirty. try cleaning it with ipa or something like that...
Old 8th November 2005, 06:27 AM   #4
I have alreay cleaned the lens. It does not make any difference.
Karma: Are there any particular caps and IC's which go bad more often. I'm not an expert on these players, so your help is more then welcome.
Thomas
Old 8th November 2005, 07:06 AM   #5
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default Perhaps it needs replacing
If the crackling you hear can alternatively be described as distortion, then the likely case is that you need the laser replaced. My Rotel RCD-(something) did something similar. Replacing the laser assembly fixed it.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
TA10 and car battery - crackling sound jtaytay Class D 5 25th February 2008 03:33 PM
crackling sound from one channel ali_azamkhan Tubes / Valves 4 23rd November 2007 09:43 PM
Weird crackling sound without B+ applied arnoldc Tubes / Valves 3 9th January 2007 10:02 AM
crackling sound CDM4 Thomas Hage Digital Source 5 4th January 2006 10:59 AM
Crackling sound in right channel of TDA1541A DAC HeadSh0T Digital Source 3 9th December 2003 10:16 PM
Page generated in 0.06647 seconds (74.41% PHP - 25.59% MySQL) with 10 queries
