Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Replacing Caps on X-CD88
Old 1st November 2005, 07:06 AM   #1
audioferret is offline audioferret  United States
Default Replacing Caps on X-CD88
A couple of questions:
I have an Onix X-CD 88 that I am modifying and I am trying to determine what replacement values to use for the electrolytics at the OPAMP.
I just ordered a set of OPA 627s on BrownDogs, so those will be the Op Amps to reference.
First off, which capacitors are the coupling capacitors? The ones right before or right after the Op Amp? Do they have to be Electrolytic or will film caps do a better job.
1. I would like to replace the following caps.
a. There are four 270mF/16V electrolytics after the op amp and chip in the signal path (2 per channel) right before the RCA jacks. I can't find lytics with a 270mF rating, so what should I use?
b. There are two 10mF/16V and one 22mF/25V lytics before the Opamps. Will it matter if I use bipolar lytics for these? I was thinking of the Nichion Muse Bipolar series.
c. The two power caps at the power supply input to the main pc board are Elna 3300mF/42V. What should I replace these with? Should I replace them? I can't find exact matches.
d. There is one more 6800mF/25V cap leading to the rest of the circuit (clock?) Should that be replaced? With what.
2. There are two regulators after the main power caps that seem to be replaceable. They are three-terminal, 1A each. What should be used to replace those?
3. The input switch at the AC mains has two yellow-brick .33mF capacitors (filters?). I would like to replace these with Auricaps to cluan up the power supply. Thoughts?
4. Last, there are two sets of unused holes along the signal path immediately prior to the RCA-Out Female jacks. Would a pair of Auricaps do any good? Suggestions?
Thanks,
The Audio Ferret
Replacing Caps on X-CD88Hide this!Advertise here!
Replacing old caps in the SP8 pre-amp enilsen Tubes / Valves 6 7th February 2010 07:02 PM
Replacing multi-section caps with multiple caps? Sir Trefor Parts 1 29th May 2007 10:17 PM
Replacing Caps in HK775? mvarney Solid State 13 20th September 2006 08:18 AM
Replacing the caps in the crossovers... dewdrop Multi-Way 13 21st February 2006 11:56 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
Copyright ©1999-2017 diyAudio
