| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I want to build an active crossover to go between a dayton rs hifi sub and an altec model 288c horn speaker at 500 hz.
I will also have to attenuate the horn from the 115db efficiency to the 89db of the woofer. I suppose a higher order crossover would be best because of the differences of the two speakers. An active crossover needs to be powered, how do i know what voltage to supply? Thanks |
#2 |
Visit
sound.westhost.com and get started. Gajanan Phadte |
#3 |
Electrons are yellow and more is better!
Check also www.ti.com and www.analog.com which have online tools. Check also Walt Jung's book about opamps whoch can be downloaded from www.analog.com In the book you have a chapter about active filters.
http://www.analog.com/library/analog..._handbook.html http://www.analog.com/library/analog..._final_PtA.pdf http://www.analog.com/library/analog...inal_PtB_F.pdf
/Per-Anders (my first name) or P-A as my friends call me |
| The Best Active Crossover - Here! | Samuel Jayaraj | Multi-Way | 33 | 13th August 2011 06:18 AM |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Help with active crossover | sunil | Multi-Way | 3 | 8th March 2004 10:44 AM |
| Loudspeaker project from scratch - driver construction, cabinet, & crossover | UncleJessie | Multi-Way | 19 | 20th April 2003 04:26 AM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 01:29 AM |
| Page generated in 0.05779 seconds (80.68% PHP - 19.32% MySQL) with 10 queries |
