| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
OK, this is going to be an electronics 101 lesson for me, but I have a few questions:
1. Do inductors have polarity? If so, is it such that the outer lead (the one on the outside of the coil's circumference) is the positive and the inner lead (on the inside of the coil) is negative? 2. Do film caps have polarity? If so, do I determine this by reading the text on it from left to right, and use the left lead as positive and right as negative? 3. Resistors to my knowledge, have no polarity, correct? 4. Can I connect all ground connections to a single point, including driver ground? That is what I've done thus far. Thanks for any wisdom you can impart! Paul |
#2 |
Electrons are yellow and more is better!
1 Yes but it's more like "windning polarity". In the way you wonder no.
2 No. Have you ever seen a film capacitor with any kind of polarity mark? ![]() 3 No ![]() 4 Yes ![]() Hint: You could always check the datasheet for a part if you wonder.
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Thanks Per-Anders, this is what I was hoping to hear. I am troubleshooting a crossover problem, and simply wanted to ensure I wasn't too much of an imbecile!
BTW, great review of the 2.5! Thanks again, Paul |
| Ess AMT polarity? Help | promitheus | Planars & Exotics | 1 | 13th July 2007 09:52 PM |
| SMD Cap Polarity, How to Tell? | DreadPirate | Parts | 3 | 10th February 2007 12:24 PM |
| GE 97F cap polarity ??? | maynardg | Tubes / Valves | 0 | 3rd February 2007 09:20 PM |
| need help xover and polarity of driver | hyl2369 | Multi-Way | 5 | 25th May 2005 02:27 PM |
| LED polarity | guitargully | Solid State | 4 | 12th January 2004 04:14 AM |
| Page generated in 0.06849 seconds (71.30% PHP - 28.70% MySQL) with 10 queries |
