Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th October 2005, 05:44 PM   #1
Question Need hEEEEEEEElp!!!! wiring problem!!!!
Hello and thanks to all audio fanatics...
I need help connecting and wiring this gear:
Mesa Boogie Triaxis preamp 6'3 jack balanced output ---> Klark Teknik Dn-405 parametric equaliser XLR balanced input (pin 2 hot jumper ON) ; and
DN-405 XLR UNBALANCED output (pin 2 hot jumper ON) ---> TC Electronics G-Force UNBALANCED 6'3 jack input.
I think the correct wiring should be:
TRIAXIS BALANCED JACK OUTPUT: TIP (+), RING (-), SLEEVE (G)
DN-405 BALANCED XLR INPUT: PIN 1 (G), PIN2 (+), PIN 3 (-)
DN-405 UNBALANCED XLR OUTPUT: PIN1 (G), PIN 2 (+), PIN 3 (DISCONNECTED)
G-FORCE UNBALANCED JACK IN: TIP (+), RING (G)
But I get -6 dB and a high frequency loss at the output of the DN-405 in comparison to the Triaxis output!!! Also, it sounds perfect if I turn off the DN-405. (???)
Old 30th October 2005, 03:43 PM   #2
kepa1 is offline kepa1  France
Hi guitaratiug,
I'm not sure I totally understood your setting but whenever you connect a balanced output with unbalanced adaptors, you lose 6db.
That would explain your loss, wouldn't it?
Old 30th October 2005, 10:10 PM   #3
Thank you for your reply, but
The signal path goes from an UNBALANCED XLR (where pin 1 and 3 are connected in the output) to an unbalanced input jack. There should be no signal loss at all in this case!
[My conclusion is that it may be occuring an impedance problem...]
bi-wiring problem - explain? mantisory Everything Else 3 17th July 2006 07:39 PM
RCA - Minijack Wiring Problem Evan Robinson Everything Else 2 22nd March 2006 05:31 AM
Zappulse PSU wiring problem ewildgoose Class D 31 31st October 2004 02:30 PM
need solution for wiring problem... I think Predsy Car Audio 8 30th July 2004 12:07 PM
A wiring thought problem Xylenz Multi-Way 9 23rd January 2003 04:58 PM
Page generated in 0.06475 seconds (69.68% PHP - 30.32% MySQL) with 10 queries
