Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th October 2005, 07:58 PM   #1
Default How to connect two relays to the same PSU
I’m going to build a loudspeaker switcher (the same pair will be shared by two different amplifiers) using a pair of Fujitsu FTR-F1 sealed DPDT relays (from Mouser). Its specs are:
Contacts: gold plated Silver alloy, 5A switching and 7A carrying only capacity (minimum 10mA)
Coil: 24Vdc voltage and 0.53W nominal power
I’ll use a stabilised 24V Switch-mode PSU (Stontronics T25006ST), rated at 0.5A. My doubts are:
1) How to power both relays from the same PSU?. I think the “+24V” dc output goes first to one of coil contacts and from here to the same contact of the other coil, and the “minus” output goes the same way to the unused coil contact in the first relay and then to the other relay “-“ coil pin (like wiring the two coils in parallel). Is this correct? Has the PSU (0.5A-rated) power enough to energise both coils?
2) Is it necessary to connect a diode (1N4001?) and a resistor (what value/rating?) between coil contacts on each relay (diode band/cathode to “+dc” input coil pin) to protect something in the circuit? In my case, there is no more components in it, only the two relays, the PSU and the wiring.
3) The cable from the relay output to loudspeakers would be a 9ft. high-capacitance ribbon type (Goertz MI1). Does it matter? Is it best to use a more conventional type? (BTW, the MI1 sounds superb).
Thank you for your help
Reed Relays Vs Standard Relays steevo Solid State 9 21st September 2009 05:08 AM
Loudspeaker Relays Bob Cordell Solid State 137 25th July 2008 07:18 PM
R2R Attenuator with Relays Bonsai Solid State 2 11th July 2008 08:51 AM
1 HP Relays jackinnj Swap Meet 0 15th November 2006 10:37 PM
Relays in amp hotscot Parts 80 31st January 2006 10:04 PM
Page generated in 0.06481 seconds (67.19% PHP - 32.81% MySQL) with 10 queries
