Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
"Audio grade" electros ?
Old 17th December 2013, 06:05 PM   #21
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
I'm not sure that low ESR is desirable for audio - most subjective tests of electrolytics rate low ESR capacitors like the FC, FM, ZL, ZLH, etc. as much harsher-sounding than relatively higher ESR (and physically much larger) caps like Elna Cerafine, Panasonic Pureism, Nichicon Muse KZ and Rubycon Black Gate.
There needs to be some other measure that has a bearing on capacitor linearity (e.g.. how straight is the V vs. t graph when charged at constant current?) as well as how constant C remains with V. All of this is rarely characterized and heavily dependent on electrolyte formulation (aqueous vs. non-aqueous, solid polymer vs. electrolytic, etc.) and chemistry, material properties of the foil, separator, etc.
It's not even clear to me that the most linear caps are the best sounding, but that's another can of worms.
Old 17th December 2013, 06:20 PM   #22
2SA991 is offline 2SA991  Germany
I use onle EPCOS SIKOREL 105 typs
Old 17th December 2013, 06:49 PM   #23
SRtom is offline SRtom  United States
Default audio grade electros
Originally Posted by jcx View Post
search: capacitor dielectric
in electronic and parts forum:
http://www.diyaudio.com/forums/searc...der=descending
You didn't specify why this is important. Are you working with coupling or filter caps? In either case most manf. equipment uses Nichicon, Rubycon. & Panasonic. If you need a tight tolerence cap for timing use a Tantalum
Old 17th December 2013, 07:00 PM   #24
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
But don't be surprised if it blows up. Sorry I couldn't resist. Older tantalums had that "feature"...
They're good now and I use the SMD versions often but I wont forget the "flash + bang" of the older drop type tantalums.
It's only audio. Member of the non modular PCB design committee
Old 17th December 2013, 08:03 PM   #25
LOL, Yeah I grew up then but they were only rated at 16V and I tried to fit them into a 50V circuit! Now you can get 35~50V types but quite pricey. That's why I asked what he was using the caps for.
"Audio grade" electros ?Hide this!Advertise here!
Do we really need high priced "audio grade" power resistors? panson_hk Parts 11 14th June 2016 10:14 AM
Urgent sale of NOS (produced in 1996) PCM63 "K" grade DAC's. Altmustech Swap Meet 1 27th August 2006 10:56 AM
Urgent sale a lot of NOS (produced in 1996) PCM 63 "K" grade! Altmustech Parts 0 26th August 2006 11:41 AM
What qualifies a capacitor as "computer grade"? G Pass Labs 26 26th October 2002 04:56 AM
