"Audio grade" electros ? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th December 2013, 11:49 AM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
maybe its similar to when saying humans needs heroes, myths, and dreams
a dream about fantastic components that will transform simple and boring electronics
sometimes we know very little, and sometimes we know too much
Old 13th December 2013, 04:37 PM   #12
jneutron's Avatar
Originally Posted by wintermute View Post
on the question of are they low esr, I just did a test and they appear to be.
tested
1. Nichicon FG 10uF 50 V 1.2 Ohms
2. generic 10uF 50V 1.4 ohms
3. rubycon ZA 10uF 50V .7 Ohms
note I did this test once before but had a panasonic FC instead of the Nichicon. it was 10uF 50V and measured about 3 Ohms.
so I'd say since panasonic FC's are low esr and rubycon ZA's are ultra low impedance, the FG (muse) is not to shabby in that respect....
from the datasheets the FG and ZA have the same leakage, and the ZA has the edge in DF, but the FG's come in higher voltage versions than the ZA, and their DF gets better as the voltage exceeds the highest rated ZA.
whether or not this means anything
I used speaker workshop to measure.... the FG was 9.9uF the ZA 9.3 and the generic 8.6..... but on a sample of one all this could be complete BS
ok to add a little more credibility I tested the other two nichicon FG's I had, both 9.9uF both 1.1 Ohms, so one thing that seems to be the case from my small sample is that the tolerance is really tight. I only have one rubycon ZA......
Tony.
A quick question. Why did you only try one frequency?
jn
Old 13th December 2013, 05:05 PM   #13
SY's Avatar
jn
Doesn't Speaker Workshop use an MLS stimulus to measure impedance?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th December 2013, 05:11 PM   #14
jneutron's Avatar
Couldn't tell ya. I saw the single datapoint for resistance and capacitance, and assumed that meant one frequency.
If I were worried about how "audio grade" a capacitor was, I'd want the date for capacitance and resistance across the entire audio spectrum. I've seen lots of lytic datasheets which show capacitance taking a dive with frequency.
jn
ps..been kinda tired of late...started last Saturday...mebbe I caught sumptin... how bout you?
Old 13th December 2013, 05:32 PM   #15
SY's Avatar
It must be the residual of getting bombed for Pearl Harbor Day.
Old 13th December 2013, 05:46 PM   #16
jneutron's Avatar
I almost lost my coffee on that one. Would you believe I've never heard that?
jn
Old 16th December 2013, 11:57 AM   #17
Originally Posted by fpitas View Post
I've noticed that various audio grade electrolytics have some damping material in them (silk, hemp, etc). Perhaps the intention is to lower microphonic effects, either from external sources or internal resonance.
Most probably, particularly for loudspeaker crossover networks, where current input is much higher, the caps could actually "sing" or mechanically vibrate.
Old 17th December 2013, 06:49 AM   #18
just another
wintermute's Avatar
jn
Because I didn't really know what I was doing?? It was 8 years ago, it would be interesting to compare the same caps with my BlueESR meter, I'd forgotten that SW actually gave the esr, so would be interesting to compare results (the blueESR does only use a single frequency from memory).
and yes SY SW does use a MLS to do the measurement.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 17th December 2013, 09:37 AM   #19
SY's Avatar
OK, so you did your measurement across the board, not at a single frequency. With SoundEasy and AudioTester, the software gives a fit to a simple model and will spit out a DCR (usually called RE).
Old 17th December 2013, 02:43 PM   #20
jneutron's Avatar
So the capacitance and esr are independent of frequency? I'm not sure that is accurate.
Single data points may be very misleading.
jn
Do we really need high priced "audio grade" power resistors? panson_hk Parts 11 14th June 2016 10:14 AM
Urgent sale of NOS (produced in 1996) PCM63 "K" grade DAC's. Altmustech Swap Meet 1 27th August 2006 10:56 AM
Urgent sale a lot of NOS (produced in 1996) PCM 63 "K" grade! Altmustech Parts 0 26th August 2006 11:41 AM
What qualifies a capacitor as "computer grade"? G Pass Labs 26 26th October 2002 04:56 AM
Copyright 1999-2017 diyAudio
