Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd October 2005, 01:25 AM   #1
Default Eagle Question. Printing for Toner Transfer meathod.
I'm new to using eagle.. I've designed a layout that I would like to pring out so I can etch it using the toner transfer meathod.. Only problem is I can't figure out hot to print the damn thing. It's probably something really obvious that I'm missing, but I've been looking at the computer screen for too long!
Can anyone give me a hand?
Old 23rd October 2005, 09:37 AM   #2
pinkmouse's Avatar
Use the CAM processor in the drop down menus to export an EPS file, then you can load that into any graphics software and print it out. At least, that's the way I do it on the Mac.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 23rd October 2005, 12:19 PM   #3
No need to export.
Choose Print, mark Black, Solid and Mirror; Scale factor = 1, page limit = 0.
Before that, on the display setting for the board (the button with 3 sqaures, blue, red, green below the "i" button), check tplace only. All other unecessary layouts associated with it will also be ruled out automatically.
By then you should only have the Ground plane/track (blue), vias and pads.
That it!
Good luck!
"There's something organic about a happy cloud of electrons" - Neutron Bob
Old 24th October 2005, 10:40 PM   #4
cetoole is offline cetoole  United States
I would use the CAM processor to generate Gerber files, which would give you a breakdown on the individual layers, drill info, silkscreen, stop mask, and anything else you need. Sparkfun has a file that makes it really easy to get what you need, read here for more information, and then when you have the gerbers, open up the individual layer, save bitmap images at as high resolution as possible, import into something like photoshop to clean up anything if needed, and print, just making sure the size is correct.
Old 28th February 2007, 06:15 AM   #5
Send a message via MSN to -_nando-_ Send a message via Skype™ to -_nando-_
I have the same question !
How do I use that cam file ?
Thanks !!
Old 2nd March 2007, 08:42 PM   #6
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default Eagle printing
Another way is to go to VIEW (when your in the board layout) and turn off everything BUT the top,, bottom, pads and Vias (this is assuming 2 sided board...if its single sided then just bottom, holes and vias) then you can choose print and solid, black....
none
Old 29th July 2007, 05:10 AM   #7
Hi !
I'm here to report a VERY sucessful toner transfer method.
I can make PERFECT pcbs, without any failure, I already made some SMD boards, with common ground layout and isolation of 0.16 mils.
The trick is:
Buy this paper: EPSON code S041117
Print it selecting the max amount of toner darkness.
Clean well the board, using that metalic sponge (I don't know the name of this in english), till you get a clean and shinny board.
Get that thing that thing that womans use to make our smashed clotches (after the wash) usable (I also don't know the name of this equipment), and put it pretty hot. Carrefully transfer it !
Then, the paper will be very well attached to the board. Don't remove it yet, fill an recipient with warm-hot water with soap and put it inside, wait 30 minutes. Carrefully remove the paper, and use a teeth brush to remove it completely.
Now you can put it in the corrosive solution.
Old 29th July 2007, 05:44 AM   #8
ashok's Avatar
post by -_nando
".....Get that thing that thing that womans use to make our smashed clotches (after the wash) usable (I also don't know the name of this equipment), and put it pretty hot......"
I just love the way you expressed yourself. This is the POWER of language. You can get across the message without knowing the right terms !! Great work ! I also take my hats off to you for expressing yourself boldly and not being fazed about ' making mistakes in a foreign language '.
By the way, the gadget is an 'electric iron'.
PS. Isn't there a smilie for tipping the hat ?
AM
Old 29th July 2007, 07:01 AM   #9
Thank you so much ! Hehe, pretty funny. I know "how english works", the rules and everything else. But as we use to talk with tecnical terms , there's some words of the "day by day" missing on my mind.
The way to improve it is traveling out of the country, or reading books etc.
I liked a lot your words, thanks !
<-- Beer is an universal word that make friends and peace
Eagle printing question. ashok Everything Else 5 25th July 2007 04:09 PM
Custom PCB manufacture question - toner transfer issues... SuperH Parts 6 22nd February 2007 07:05 PM
Laminator for PCB Toner Transfer? dfdye Parts 16 29th May 2006 02:52 PM
Toner transfer with a twist -- anyone tried this? rif Everything Else 17 7th September 2005 12:10 AM
Page generated in 0.09980 seconds (78.41% PHP - 21.59% MySQL) with 10 queries
