| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hey,
I have just aquired a mm electronics 12 channel mixer and am going to replace the op amps on the output boards as at some point in its history one of the boards have been rebuilt and the op amps are noi longer the same on both channels (and one channel seems to be slightly noisier) they are all versions of the 741 that are being used but i want to replace them with somethign a little better and am wondering what would be best? mabey the LF351 or NE5534? Any help would be apreciated, Owen |
#2 | |
Account Disabled
having seen the inside of quite a few "high-end" mixers, I can assure you that either the lf or ne would absolutely constitude "high-end" for this application. Popular "high-end" opamps for this kind of applications are actually those TL0xx series opamps. It is not surprising that you see the 741, or sometimes 324s in those mixers. And think all the people who argue about how much differrence they hear in those modern opamps when the signal has gone through a few 741s. |
#3 |
do not use tl07* series on the outputs. They do not like cable capacitance. If 741s work, well sort of, then 5534 will give good output capability, but check for pin compatability regarding offset and compensation. You will also need to check the output gain since the 5534 must be more than times 3 or +5db from memory.
regards Andrew T. |
#4 | |
#5 |
A 5532 might be a good choice. They have good drive capability and they perform well at unity gain.
Frank |
#6 |
opa27(bb/ti), op27(ad) and lt1007 are bipolars designed in part with audio in mind
they will match/silightly better the 5532/4 on noise opa134, opa604 are fet input and slightly noisier than good bipolars but better than 741 ad743 is the lowest noise fet op amp I know of faster op amps may all have trouble with large cap load from long cables, 50-100 ohm series r or ferrite bead should cure any problems |
#7 |
I use opa227 in a mic preamp, it's low noise and easy to wrk with.. but the 5534 is hard to beat...
#8 | |
Account Disabled
it depends. those current opamps used for adsl line drivers are very fast and excellent driving capacitive loads. |
#9 |
Electrons are yellow and more is better!
jcx is right that many of those ADSL opamps are poor in driving capacitive loads unless you don't read the datasheet first....
/Per-Anders (my first name) or P-A as my friends call me |
| Replacing NE5532 Op-Amps with AD827? | KevinLee | Solid State | 5 | 12th June 2010 05:24 AM |
| Replacing A 1/4" Headphone Jack On A Mixer | djFM | Headphone Systems | 2 | 5th February 2009 12:16 PM |
| Help replacing TL072CN op amps for TLE2072CP | SoundSpot | Solid State | 4 | 23rd December 2008 11:31 AM |
| replacing op-amps with thermionic valves | jenks | Tubes / Valves | 2 | 25th March 2008 01:45 PM |
| DJ Mixer | Samuel Jayaraj | Solid State | 4 | 2nd February 2002 09:07 PM |
| Page generated in 0.10768 seconds (80.66% PHP - 19.34% MySQL) with 10 queries |
