Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th October 2005, 07:07 PM   #1
Send a message via MSN to youyoung21147
Question Ultrafast rectifiers ?
Hello,
I'm planning to build a PSU for my future chip amp (surely a GainClone) and I am wondering which rectifiers I should use.
I plan to order some samples from OnSemi to compare but I ask here what kind of rectifier I should use :
I know they need to be fast, 35ns is a good value.
But concerning the rest I don't know. Why do people like MUR860 diodes more than the other ones ?
I was thinking that 8A for 2 amplifiers isn't enough.
So why not use 16A or 30A ? Are small ones more "refined" ? Or is bigger better ?
Concerning the rating, should it be adapted to the circuit or is it better to use higher voltage ratings ? (eg. 200V or 600V)
Finally are there any other parameters to take into consideration when a choice has to be made ???
I'm a little lost so every comment is welcome
Old 11th October 2005, 07:40 PM   #2
mzzj is offline mzzj  Finland
Default Re: Ultrafast rectifiers ?
Originally posted by youyoung21147
Hello,
Not only fast, but also soft-recovery.
They are in fashion
Why not use schotky-diodes. ? Faster than ultrafast and absolutely soft-recovery. plus low-losses. OK, if you need more than 100V rated diodes then schotkies are not first choice. (altough 200v ones are becoming more availlable and 600&1200V SiC-schotkies are also availlable.)
Old 11th October 2005, 09:35 PM   #3
just another
wintermute's Avatar
The MUR860's are 50ns but have very high (600V) ratings... go to www.farnell.com and do searches on soft recovery and ultra fast recovery, you should get a large selection some as fast as 20ns whilst still handling the 8A of the MUR860's..... not sure on the voltage.....pobably 200V max for that speed...
as for which ones work well???????
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 11th October 2005, 10:51 PM   #4
Send a message via ICQ to bezobraznia
Default ok, check these:
Check BYW29E-150, BYW29E-200, BYV-series etc.
Right now I'm with first type on my Gainclone and with similar for my DeathOfZen-Class-A amp and I'm very satisfied with results.
Great diodes - ultra fast, fast recovery etc.
Best Reggards
Niki / Bulgaria
WELCOME TO THE WORLD OF HIFI
SE + FULLRANGE RULEZ!
Old 12th October 2005, 07:24 AM   #5
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Ultrafast rectifiers ?
Originally posted by mzzj
also soft-recovery.
That is actually the important bit.
Any time your required voltage is low enough these are hard to beat...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th October 2005, 11:00 AM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: ok, check these:
Originally posted by bezobraznia
[snip]- ultra fast, fast recovery etc.
Best Reggards
Niki / Bulgaria
... which is the same of course. Ultra-fast refers to the recovery, NOT to the forward path.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 12th October 2005, 11:46 AM   #7
Mmmm Interesting !
: Not only fast, but also soft-recovery.
==> How do you quantify "softness" of diodes ?
Is it worthy to use some 16A or 30A for more "safety" ?
Is it better to use 600V instead of 200V ?
Old 12th October 2005, 11:50 AM   #8
10x for correction... but You follow my point
Old 12th October 2005, 07:37 PM   #9
I found some "Ultrasoft" rectifiers at OnSemi : the MSR1560.
Rated 600V 15A
They are said to be ultrasoft, and have a pretty good 45ns Trr.
I assume they are good candidates aren't they ?
I also found some Shottky rectifiers : MBR40250.
They have a good 35ns Trr and are rated 40A 250V
They are oversized, but I assume it doesn't matter.
Apart from price, what model would you recommend me between those ?
Are there measurable parameters apart from Trr that would help me guess which or which part is the best ??
Old 12th October 2005, 07:56 PM   #10
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I'm missing something, what exactly is it about 8.33mS pulses that needs switching 10^5 times faster?
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Ultrafast NoCap-ClassAB MikeB Solid State 94 23rd July 2007 05:56 PM
Ultrafast rectifier and heatsink deal I_Forgot Chip Amps 0 30th October 2006 03:42 AM
BYV44-400 ultrafast rectifier diodes. bigparsnip Swap Meet 0 6th May 2004 09:11 AM
Ultrafast Diode bridge substitution fr0st Parts 10 16th February 2003 04:00 PM
Page generated in 0.10490 seconds (82.87% PHP - 17.13% MySQL) with 10 queries
