Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th October 2005, 12:07 PM   #1
Default depotting transformers
Has anyone depotted an epoxy potted transformer? I have a CAL Alpha with the transformer pulled right out, and the leads broken off. Replacements are unobtanium.
Old 11th October 2005, 12:11 PM   #2
SY's Avatar
Epoxy is hopeless to remove easily. What you need to do is CAREFULLY chisel it away from near where the wires come out. Once you can expose a few millimeters, new leads can be soldered on.
I just had to do this with some nice UTC transformers- it was a pain, but I've got good connections now. And once the transformers are mounted, no-one can tell without flipping the amp over and removing the bottom plate.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 11th October 2005, 03:27 PM   #3
dnsey is offline dnsey  United Kingdom
I agree - but I'd 're-pot' the new terminations afterwards. The leads have a nasty habit of breaking again where the digging out has weakened them, and it's almost impossible to repeat the process sucessfully.
Old 11th October 2005, 04:08 PM   #4
SY's Avatar
I'm sure there's a way to do that, but everything I've tried on my transformer didn't stick well. Two part epoxy, PMMA resin, two part polyurethane, and hard silicone all let go. I suspect the original potting was a filled phenolic, but I don't know for sure. If you have any suggestions, I'd like to try them.
Old 12th October 2005, 12:20 AM   #5
TwoSpoons's Avatar
If you heat epoxy enough (90-120 C IIRC) it becomes jelly like, and is easy to chisel away with a screw driver. It goes back to its glass state as it cools. I've done this with some large epoxy potted high voltage transformers that I used to work with.
I found a hot air gun (paint stripper type) is ideal for heating.
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
FS: Transformers alexcd Swap Meet 0 19th November 2008 08:34 PM
my first amp (transformers???) fitchmicah Chip Amps 5 7th January 2007 07:26 PM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
transformers then_dude Tubes / Valves 3 3rd June 2004 11:10 PM
Page generated in 0.07570 seconds (71.87% PHP - 28.13% MySQL) with 10 queries
