Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th October 2005, 09:14 PM   #1
frugal-phile(tm)
planet10's Avatar
Default Mystery Chokes
I got given these chokes (2 the same) -- they are substantial, have the sound of liquid sloshing around in them when you shake them (they fellow who gave them to me said oil filled), are rated for very low inductance, but large current capacity.
Can anyone enlighten me as to their purpose?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th October 2005, 09:15 PM   #2
frugal-phile(tm)
planet10's Avatar
And a picture of the choke...
Old 7th October 2005, 09:27 PM   #3
SY's Avatar
If these are old, that's probably PCB inside...
If I were to guess, these were made for filament or heater supplies.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 8th October 2005, 12:25 AM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Nice stuff.
Considering the apparent age it probably does use PCBs but as long as it stays sealed it's safe (even if it doesn't, its reactivity is debatable so there ).
0.11H is around the critical value for say 300V 1A, so that makes enough sense. No good for less than that critical value, but...
It may've also been used at lower voltage for consequently wider current range, but I don't know anything tubed that would need that kind of power. Could also be early transistor era, but I doubt they would've needed parameters like that with 50s and 60s germanium junk as it was.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 8th October 2005, 05:29 AM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Add 12uF in parallel for a 120 Hz resonator. Connect in series with your DC DHT heaters to reduce hum.
NB Check my math, it's always suspect
Old 12th October 2005, 01:37 AM   #6
JesseG is offline JesseG  Canada
JesseG's Avatar
Hey Dave:
I tracked down those chokes - they are filled with PCB. They came from the transmitting stage of the Coastguard radio station here in Alert Bay. Westinghouse 20,000 watt HF (240 Khz) transmitter ca. 1940. Removed July 1967.
Same with the trafor and chokes I have - these came from the audio amplifier section (shame this was lost) - it drove about 18 speakers around the site on 75V step-up-down trafors on the speakers (remember the highschool PA system).
Now, you just have to figure out what to use them for.
Cheers
"If we crashed our cars as often as we crashed our computers, we'd all be dead!"
Plate chokes & Power chokes JC951t Tubes / Valves 3 19th October 2006 03:18 PM
Two chokes in one pot? vax9000 Tubes / Valves 2 7th June 2006 09:42 AM
Chokes 4 everyone! Circlotron Parts 15 9th May 2005 07:51 PM
Chokes in PSU diyman Solid State 6 20th February 2004 05:13 PM
Rf Chokes - Sos b_online Parts 0 14th May 2003 11:27 PM
Page generated in 0.07561 seconds (78.44% PHP - 21.56% MySQL) with 11 queries
