Hybrid thermometer with Nixies - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th October 2005, 10:15 PM   #1
Default Hybrid thermometer with Nixies
Hello fellas!
I'm not in the mood these days for programming a uC, so was wondering for the several possibilities of making a Nixe thermometer.
One is a electromechanical approach where an analog needle thermometer directly activates eahc nixie cathode, and the other using an LM35, but interfacing it to the Nixie using common logic IC/discrete components is intriguing me.
Any thoughts?
"There's something organic about a happy cloud of electrons" - Neutron Bob
Old 7th October 2005, 12:08 AM   #2
moamps is offline moamps  Croatia
http://www.merseypub.com/nixie/nixie2.htm
Old 7th October 2005, 09:33 AM   #3
thank you for the link moamps, but it has a PIC in it... :S
Old 8th October 2005, 03:13 AM   #4
..suppose one digit is easy with a LM3914/15 bargraph driver
varta lviv
Old 8th October 2005, 03:23 AM   #5
Thinking out loud:
LM35 used to set up voltage on one leg of a comparator
constant current source charges a cap connected to other leg
comparator output used to gate an oscillator which drives a counter which drives the nixie
reset start again?
varta lviv
Old 8th October 2005, 10:24 AM   #6
That LM3914 is a very good idea!
Old 10th October 2005, 08:32 PM   #7
Exclamation Basic display schematic - is this ok?
Here's a display schematic using 4 LM3914.
The datasheet is badly explained as to more precise indications for the pins, so i used a voltage divider to setup more precisely the voltage roll-off points.
What's the general opinion? Is it ok?
The output transistors for the nixies are missing, as is the LM35, since they can be placed on a different place/board, and i could also use a LED/Nixie dual display thermometer.
Thank you to everyone.
PS: Can someone explain in layman terms how to use in a more correct way the LM3914?
Old 12th October 2005, 12:17 AM   #8
I'm having trouble figuring out how you will drive incremental nixies.
We need a higher resolution diagram- the writing is hard to see...
varta lviv
Old 12th October 2005, 01:36 AM   #9
jackinnj's Avatar
anything you can do with a PIC you can do with solder and a bunch of TTL -- but you will go insane in the process -- parenthetically I made my first impedance tester out of discrete TTL.
National has some Nixie driver schematics on their website.
I think that the Dallas Semi thermal devices might be easier to interface...
Old 12th October 2005, 02:44 AM   #10
but it is fun to think in a different direction
The challenge to me AFAICT here is to be able to expand past the first bargraph/nixie "module".
Seems the higher next higher order module (eg"tens") unit would need to use its own output to step-shift the lower order's (eg"ones") "reference"/ground.
or just throw a bunch of TTL at the problem....
varta lviv
IN18 nixies exurbia Tubes / Valves 8 23rd July 2012 03:27 AM
Reading the thermometer, Canadian style Cal Weldon The Lounge 20 26th February 2009 12:40 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 05:16 AM
Why hybrid CCS? leadbelly Tubes / Valves 2 17th January 2006 11:03 AM
Copyright 1999-2017 diyAudio
